265s vs 285s
Old Jan 23, 2010 | 06:55 PM
Tyler_02's Avatar
265s vs 285s
I have not gotten pics of my new truck up yet but i am running stock size. Question is will i notice a miles per gallon loss and power loss going from 265 to 285s Thanks guys
Old Jan 23, 2010 | 08:05 PM
wytesyko's Avatar
I didnt notice much.....But I put my 285's on at 55 miles, so im no helpSORRY.
Old Jan 23, 2010 | 08:11 PM
Colo_River_Ram's Avatar
With age comes the cage
What G R do you have?
Old Jan 24, 2010 | 08:50 AM
Tyler_02's Avatar
Colo_River_Ram.....What did u mean by G R?
Old Jan 24, 2010 | 09:11 AM
megacabdad's Avatar
Gear Ratio...
Old Jan 24, 2010 | 09:13 AM
Dodgezilla's Avatar
I just went back to 265s from 285s. Mileage is about the same for me.....
Old Jan 24, 2010 | 09:27 AM
Tyler_02's Avatar
I guess i should of mentioned that...I have 3.73's anyone have pics of 285s on there trucks
Old Jan 24, 2010 | 10:24 AM
Dodgezilla's Avatar
Look in my gallery...
Old Jan 24, 2010 | 12:49 PM
Tyler,
Go to this link and type in your info:
http://www.miata.net/garage/tirecalc.html
You should be fine with your 3.73 GR, If your pulling 20K trailers up 10K passes daily then I would not recommend it.
Old Jan 24, 2010 | 02:14 PM
AH64ID's Avatar
I didn't notice a differnce when I went from 265 to 285's. My next move it to 255/80's. They are lighter than the 285's, and roll 11 times less per mile, so they should help mpgs.
Old Jan 24, 2010 | 02:24 PM
What RPM are you turning at 75 with that set up? I turn about 2400 and would like to slow it down some so I'm thinking 285's or 315's would be a good step from the 265's..
Old Jan 24, 2010 | 02:28 PM
AH64ID's Avatar
I turn 2160 at 75.
If your refering to your 05 with a G56 285's would drop you to about 2350, and 315's to 2230. You may also consider 285/75's, they would drop you to 2260 rpms.
Old Jan 24, 2010 | 02:37 PM
You should be getting some good mpg's in that range.. I drop to the 18's when I get over the 2200 mark under that I'm at 20..
I don't want to go to tall on the tires as I pull a GN
Old Jan 25, 2010 | 07:48 PM
rams2500's Avatar
285s look so much better!
Old Jan 25, 2010 | 07:57 PM
AH64ID's Avatar
I don't do too bad. At 80 I am at 2325. I did a 2500 mile trip in october doing 80 90% of the time and averaged 16.3 mpgs. I am not going to complain about that.
Taller tires are good and bad. One is they drop rpm's in OD so its harder to pull, but they allow you to go a bit faster in 5th for the same rpms. With a G56 and a .79 OD ratio I am not sure you would see any decrease in pulling power with 255's. Personally with the NV5600's .73 OD there are many more hills I can't pull in 6th that I could if I had a G56.. So I figured why not drop the cruise rpms and 5th gear rpms at 65 a bit more.
