2011 oil change?
2011 oil change?
I just purchased a new Dodge 2500 and I have oil from my old Ford it is 15W/40 Rotella. Will this be OK or not? What weight oil should I be running in my Ram?
You had oil left over from a Ford????
Just joking.. Ya, you have to make sure the oil meets the CJ-4 criteria for DPF systems. Most oils now display symbols stating they are compatible with DPF equipped engines.
CJ-4 isn't all synthetic. It has to do with fuel and soot dilution and not just capable by synthetic stock. In Canada I use Esso oils now some of those are moved over to the Mobil line.
Mobil Delvac 15W-40
Mobil Delvac 15W-40
Bradjun1
Mar 10, 2011 06:41 PM
jmccart
13
May 27, 2009 09:45 PM
doitl8r
Jun 4, 2004 11:14 AM
