2008 2500 rear axle
Old Jul 9, 2012 | 04:12 PM
ctzdavis's Avatar
2008 2500 rear axle
So I got a rubbing noise in my rear diff. Metal in my lubricant. $800 at the local shop to replace all the bearings if nothing else is wrong. Anybody know where I can get the torque specs for the ring and pinion gear nut or any information on the procedures for rebuilding it myself?
Old Jul 9, 2012 | 11:12 PM
ctzdavis's Avatar
So no rocks in the brakes. No major chunks of metal in the 75-90. I can only conclude that I need new U-Joints on the rear driveline.
Old Jul 10, 2012 | 04:50 PM
ctzdavis's Avatar
I replaced the U-Joint. Everything is ok.
Old Jul 14, 2012 | 03:12 PM
Hintonc393's Avatar
Metal in oil is the first sign of a problem but I have rebuilt many axles and you need to check the entire axle in detail. Pull the hubs off and check the bearings pull the carrier out and check to see that the bearing cups have not spun in the housing. If you miss it the first time you will pull it back apart again. The axle tubes need to be cleaned out, any metal left in the axle will shorten the life of the new bearings.
Old Jul 14, 2012 | 05:51 PM
Gatorama's Avatar
A bad u-joint will NOT cause metal in the diff oil. How many miles are on the oil? Is it a very fine deposit of metal on the magnet, or does the oil looks like metalflake paint?
Old Feb 1, 2013 | 12:39 AM
ctzdavis's Avatar
Replaced the u Joints all is good. No noise except for a clunk, I am thinking the fron U Joints are next to be replaced.
jbjarko
Dec 7, 2008 10:32 AM
Red3quarter
Sep 20, 2008 11:30 PM
Chrisreyn
May 17, 2008 10:55 PM
Chrisreyn
Jan 13, 2008 06:30 PM
MX429
Aug 20, 2006 06:41 PM
