2007 tranny problem
Old Jun 13, 2009 | 01:22 PM
CameronD's Avatar
Unhappy 2007 tranny problem
Need some info or help.
bear with me.........
here is what happened.......
pulled out of parking lot and was rolling too slow for 3rd,
pulled it back down into 2nd, missed and ground reverse
not hard mind you but enough evidently.....
next time I tried to put it in reverse it was hard to get it in gear,
pushed harder and I have nothing, no grind, no noise, nothing,
tranny sounds good and operates great in all forward gears,
can now easily put shifter in reverse but no go
what did I do???????
2007 6.7 6spd 4wd 4dr dually
67,000 mi
it's white if that helps
Old Jun 13, 2009 | 06:00 PM
ratlratl's Avatar
MMMmmmm.... Grits!!
I had problems with my '02 like this. Started with the hydraulic assembly. Then changed out the clutch to solve it. Any power adders? Is it the original clutch and DMF?
Chris
Fronty Owner
Nov 17, 2007 12:44 PM
burners_banshee
Sep 10, 2007 02:03 PM
ID2500Ram
Apr 29, 2007 11:31 PM
