2007 6.7L Cummins 4x4
Old Mar 27, 2010 | 03:39 PM
neby's Avatar
I bought a 2007 6.7L Cummins 4x4 from a guy who said it was in a flood. The truck won't start and doesn't have compression. I opened the valve cover and the rocker arm was off the pushrod and the crosshead was next to the valve spring. The owner claimed he never ran it while in the water, but he probably tried to start it. I am going to pull the head. Do you think it's a stuck valve, bent valve, or worse? Can water some how bend the valve? Maybe corrosion made it stick to get slapped? Rings are destroyed? What should I expect to see?
Old Mar 27, 2010 | 08:56 PM
Blake Clark's Avatar
A war zone....
Good luck. Take some pics and post em up. Interested in seeing how your progress goes.
And welcome to the DTR!
Old Mar 28, 2010 | 05:04 AM
fitter48093's Avatar
Excpect to see bent valves and pushrods. Broken cam shaft, damage to pistons, rings and possible bent crankshaft. Good luck, hopfully it won't be too bad. The condition that causes this is called hydrolock; water will not compress therefore the energy from trying has to go somewhere.
Old Mar 28, 2010 | 09:22 PM
2171CTD's Avatar
Id tear the engine down and do a full rebuild. Do it right the first time so you dont have any suprises later down the road. Good luck.
Old Mar 29, 2010 | 07:40 AM
patdaly's Avatar
And don't forget, before you get very far replacing bent or broken stuff, you can buy a 6.7 reasonably cheap and drop it in.
Old Mar 29, 2010 | 09:15 AM
neby's Avatar
The flood was actually the storm surge from Hurricane Ike. It was in sea water. So far, I have replaced the dash with the wiring harnesses, the engine wiring harness, the distribution module (fuse block), and solenoid pack in the transmission, and got it flashed at the dealer. Now, it cranks when I turn the key. All that has taken me about 8 months to accomplish. I sold my old diesel excursion to buy this. I paid $7500 for it. It sounds okay when I crank it...there's no knocking...and the push rods are not bent- just from what I see under the valve cover. I am worried about bent piston rods, but I'm looking for the compression problem. Hopefully, I will have the head pulled today. Is anyone suspicious of an exhaust brake sticking? And if there is a bent valve, how would it get bent from water? Maybe I should just buy a new engine. Anyone got one for sale?
Old Mar 29, 2010 | 09:17 AM
neby's Avatar
[IMG][/IMG]
Old Mar 29, 2010 | 04:54 PM
EverydayDiesel's Avatar
what is a new 6.7 going for these days?
Old Mar 29, 2010 | 04:56 PM
capnp72's Avatar
I wouldn't replace the engine if you can get it running for a reasonable $$$. I think the biggest thing that I would worry about would be the electronics but you replaced most of that it sounds like.
Old Mar 29, 2010 | 05:33 PM
neby's Avatar
I priced a used 6.7 today. With a 90-day warranty, used, I'm looking at around $5000. That seems like more than I would pay for a rebuild.
Old Mar 29, 2010 | 06:57 PM
More than you would pay for a standard rebuild. While you got that thing open I would prepare it for a hardcore build up. Better gaskets, studded head etc....
If I was in your situation and had the cash to boot, Id be building one heck of a bad 6.7
Old Mar 29, 2010 | 07:37 PM
got_soot's Avatar
Soot For Brains!
Ya I totally agree. Here is your chance to build a engine to your own specs. Nice charger,head studs, ported head, upgraded cam ect..hopefully nothing wrong with the bottom end and its in the valves.
Old Mar 29, 2010 | 09:03 PM
neby's Avatar
I wasn't planning on taking apart the whole thing- just the head as long as nothing else is wrong, but I see your point; however I already have a near 600 hp '71 Plymouth Roadrunner with a 440. I just want a good truck for a daily driver. Buy, if the problem is in the head I will consider putting some money in the head. Might as well...
Old Mar 29, 2010 | 09:14 PM
I understand, bet that RR is awesome. Good luck with the rework.
Big iron dave
Nov 23, 2009 05:38 PM
V.R.Wheeler
Aug 4, 2007 01:00 PM
ID2500Ram
Apr 29, 2007 11:31 PM
