2007 6.7 6spd auto fuel pressure gage?????
Old Jul 22, 2013 | 08:48 PM
mt72916's Avatar
Is it necessary to install a gage to monitor the fuel pressure from the fuel filter to the high pressure pump?
Where would the best place to hook up a gage if necessary?
thanks
I only use this truck less than 2000 miles a year for hunting and occasional taking a calf to market.
Old Jul 25, 2013 | 09:14 AM
xcc_rider's Avatar
Necessary? I don't think so, not with your limited mileage and as such, limited risk.
Its a nice thing to watch if you're putting high mileage on the truck and filling up constantly at new or different stations. In that case you're at high risk of plugging the filter and starving the pump.
There are several kits available that either mount on the pump inlet or hose between the filter and pump. I like the idea of adding a fitting in the hose for the sensor. Just make sure there's no debris left from cutting it left inside.
Another option is a low pressure alarm light. The sensor is added at the hose fitting on the pump and a light mounted in the dash. It is set to come on when the supply pressure drops below 5 psi. I believe this costs around $60. You'd have to check which gauge setup you might want to compare prices.
But then again, your risk is low. I do about 8k a year on mine and feel I'm at a low risk also and haven't done either installation as of yet. I am considering the alarm one in the future though. (Gotta put something on the xmas list)
USMC64-70
18
Apr 3, 2006 01:32 PM
westport
Nov 24, 2005 01:43 AM
windkid4
Aug 31, 2005 09:44 AM
norsk
Jul 19, 2005 08:26 PM
NavyChief
May 23, 2005 09:44 AM
