07 auto- won't go into 4HI....
Old Oct 8, 2009 | 03:44 AM
greg_bingham's Avatar
truck's stock with 40k on the clock.
i rarely use the 4wd. just to back into the ditch to load the 4 wheeler... so i don't rut the grass....
it won't hit the detent in 4HI, no matter how hard i pull on the lever (it's not the electro-**** version). it'll actually go into 4HI, but it will kick itself back out if i let go of the lever.
goes into neutral, and 4LO perfect.
any ideas?
GREG
Old Oct 8, 2009 | 06:52 AM
Hvytrkmech's Avatar
Do you put then tranny in neutral when shifting the transfer case? I would also take a look at the linkages to make sure nothing is bent.
Old Oct 8, 2009 | 07:44 AM
gsbrockman's Avatar
Are you engaging 4WD while the truck is in motion or when it is stationary ?
Greg
Old Oct 8, 2009 | 04:16 PM
tried with trans in neutral- no luck...
tried both in motion (~5mph) and sitting still no luck..
i'll have to look at the linkage.. wheni get back to the states..
GREG
snoproAndy
17
Dec 16, 2009 07:23 AM
spdnby
16
Aug 21, 2009 09:10 PM
DISLSMOKE
Mar 9, 2007 10:29 PM
LanceD
Competition / Pulls / OffRoad
20
Jan 9, 2007 11:18 PM
thejoker502
May 7, 2006 11:03 PM
