Write Up On OD / TCC Set Replacement?
Old Dec 12, 2014 | 08:35 PM
Labreapits's Avatar
Hello everyone,
I am trying to find a write up on how to replace the Overdrive & Lock-Up Solenoids. Can someone point me in the right direction? I have search the site, but I have not been able to find one.
Old Dec 14, 2014 | 01:04 PM
Spooler's Avatar
I have never read a write up for those to be replaced. What's going on with your truck? Maybe it is something else causing your issues.
Old Dec 14, 2014 | 07:48 PM
Labreapits's Avatar
I am having problems with the trans temp light coming on and dropping out of od, so I am replacing the Governor Pressure Solenoid, Governor Pressure Transducer, AM Output Speed Sensor, and was going to put in new Overdrive & Lock-Up Solenoids with wiring harness. I am sure that it is overkill, but I figure replace it all while you are in there.
My only issue is that I do not really want to drop the VB. I have watched utubes of it being done, out of the truck, and it looks possible to make the replacement without dropping the VB, but I would like to talk to anyone who has done it.
SLSD400exGUY
Oct 13, 2011 05:50 AM
vtailflyer
Apr 2, 2004 10:54 PM
daystar
Feb 19, 2004 06:21 PM
slayerfish
Jan 7, 2003 08:08 PM
RickCJ
Dec 18, 2002 02:23 PM
