wont start
Old Apr 4, 2014 | 10:21 AM
marvslg1's Avatar
wont start
i had my o3 5.9 scanned and it only has 2500 lbs of fuel pressure at idleand it needs 5500 any answers? it will start on either and run but will not idle and starts to smoke at low rpms. any help?
Old Apr 4, 2014 | 01:26 PM
BigIron70's Avatar
Cummins Guru
Set fuel pressure is what the ECM is requesting high pressure pump to deliver based on load conditions placed on engine. Many things can cause low fuel pressure. Leaking injectors, fuel tubes, pressure limiting valve, high pressure pump, fuel control actuator. Perform injector return flow test first, then PLV test. Injector contribution test can help determine if all injectors are working at 100%. Lower % on any one injector can help determine which injector is leaking. Loose fuel tube nut will also cause no start or long crank time. Tighten all fuel tubes (3) to 37 ft. lbs. and retest.
1 - HIGH-PRESSURE CONNECTOR (TO FUEL INJECTOR)
2 - O-RING
3 - CONNECTOR RETAINER
4 - FUEL RAIL
5 - HIGH-PRESSURE FUEL LINES
6 - LOCATING PINS
Old Apr 4, 2014 | 01:55 PM
marvslg1's Avatar
thank u i will try that one more thing , after 1200 rpms it carries good pressure just will not idle and starts to smoke at low rpms
Old Apr 4, 2014 | 08:48 PM
marvslg1's Avatar
help
can anybody help plz!!!!!!
Old Apr 4, 2014 | 10:06 PM
StealthDiesel's Avatar
1. Have you followed the steps outlined by Big Iron?
2. What does your low side (lift pump) fuel pressure gauge read with the key on engine not running?
Old Apr 5, 2014 | 06:52 PM
marvslg1's Avatar
lift pump is new after market high preformance
rustydeeretech
Jun 16, 2010 09:41 AM
CoolumConst
Oct 11, 2008 10:00 PM
Stroked-Z
Oct 4, 2008 11:28 AM
qcstunter
Jan 9, 2007 04:10 PM
Desert Diesel
Dec 5, 2002 08:53 PM
