Will my Check Engine Light go away?
Old Sep 2, 2007 | 06:59 PM
00Dog's Avatar
I did some searching and I think I got a CEL and P0191 from turning the key on too long without starting the engine. The light has been on for a week. Do you think it will eventually go away or do I need an appointment with the dealer?
Old Sep 2, 2007 | 09:20 PM
robmints's Avatar
The cel should go off if the problem is gone. I think it is 5 starts. But it might be 4 or 6. At least mine does.
Old Sep 2, 2007 | 09:27 PM
gerry's Avatar
I have an 05.. that code is a rail pressure mismatch... It will not go away.. I have had it twice and both times had to have the dealer clear it...
mine happened in the drive through.. shut the truck off to order and started it to quick.. The rail didn't have time to bleed to 0 psi... the truck looks for 0 psi on the rail when it starts...
Gerry
Old Sep 2, 2007 | 09:41 PM
53 willys's Avatar
it's not "starts" it's drive cycles....a drive cycle is when the truck starts cold and goes up to normal operating temp...a certain amount of info has to be sent back to the ecm from certain sensors before it is considered a drive cycle....it could take a month to rest a CEL if you don't drive much or very far....you should also make sure the code is not there for a reason.
Old Sep 2, 2007 | 10:14 PM
ptgarcia's Avatar
I had a CEL that wouldn't go away, but when you tried to pull the code there were none. Had the CEL reset by a mechanic and it hasn't returned.
buddy26
Feb 15, 2008 12:17 PM
choppers555
Oct 16, 2007 12:29 PM
keithstef
Jul 30, 2007 03:58 PM
stoneage
Feb 21, 2007 05:01 PM
alltimelow1
Apr 6, 2005 07:28 PM
