will 2500 hold up
Old May 10, 2007 | 12:31 AM
jbworm20's Avatar
will 2500 hold up
i am about to haul a 12,500 lbs tractor about 500 miles round trip and was wondering if a 3/4 ton auto will hold up ok or not. I also have a 1 ton ctd but its alittle older and just kinda wanted to ride in the comfort of an 06 any imput would be cool thanks
Old May 10, 2007 | 03:27 AM
Goober's Avatar
What does the trailer weigh in at.
Old May 10, 2007 | 03:34 AM
jbworm20's Avatar
I really dont know off the top of my head its 40ft
Old May 10, 2007 | 03:38 AM
PourinDiesel's Avatar
Yeah it will hold. You might use tow/haul mode if you have a real heavy load though.
Old May 10, 2007 | 07:13 AM
deerefarm06's Avatar
you'll be fine...just take it easy.
Old May 10, 2007 | 08:31 AM
rockcrawler304's Avatar
As long as the trailer brakes work properly you will be fine. If you feel uncomfortable, just take it slow and easy. The truck will be fine.
Old May 10, 2007 | 03:26 PM
Goober's Avatar
You will be alright 20k runnin down the road is not that much weight.
Old May 10, 2007 | 07:02 PM
Jfaulkner's Avatar
Muted User
keep in mind the only difference in the 2500/3500 (in the 3rd gens) is 2 helper springs. And maybe 2 extra tires depending on the truck, the rest is the same.
Old May 10, 2007 | 09:29 PM
Scooterloo's Avatar
Really? No difference in brakes or tow capacities?
Old May 10, 2007 | 10:08 PM
jbworm20's Avatar
i just hope im not poppin a whellie going down the road I mean I know i got plenty of power its just the truck im kinda worried about but i go tommorrow no turning back now
Old May 11, 2007 | 01:05 PM
dadwolf2's Avatar
I've got an o5 and the only difference is the rear leaf springs. Engine, drivetrain, rear diff, and tires are the same as the 3500 SRW.
Old May 11, 2007 | 02:32 PM
Jfaulkner's Avatar
Muted User
Nope. The only "tow capacity" difference is what's on the sticker. So if someone wanted to get picky, yes the 3500 can legally tow more. But as far as being "safer" I vote no since the trucks are almost identical (except for 2 helper springs).
Old May 16, 2007 | 04:10 AM
jbworm20's Avatar
well I did it and the only thing i could tell that I would have liked to be alittle different is take off. other than that i ran down I 40 at 75 or 80mph the faster i went the better it ran
Old May 16, 2007 | 08:35 AM
LongRanger's Avatar
I guess the torque converter is the weak link when taking off with a load. Did it rev up a lot when you were taking off?
Old May 16, 2007 | 06:50 PM
Goober's Avatar
I just read that the 3500drw had 52mm breaks and the SRW has 45mm.
