Why do greaseable ball joints last 10,000km only on our 3rd gens?
Old Jan 24, 2010 | 12:24 PM
bb45's Avatar
lol no offence thats where the grease gun attaches to the ball joint
Old Jan 24, 2010 | 01:51 PM
04.5 ctd fan's Avatar
Thinking of changing my screen name to zerks. Thanks for the schooling.
Old Jan 24, 2010 | 02:07 PM
cincydiesel's Avatar
Originally Posted by Colo~Dirtbikers
Still rolling on the factory hub bearings too. I just greased em a couple days ago.
Carey
Are you greasing them from the abs sensor?
Old Jan 24, 2010 | 08:54 PM
littlebigtruck's Avatar
I just replaced balljoints on one of our trucks that had about 330,000mi on the clock. Wish I would have known about the XRF's before I put the greasable Moog's in, but time will tell how long they last. Does anyone have a link to the manufacturer of the XRF's handy?
Old Jan 24, 2010 | 09:17 PM
Colo~Dirtbikers's Avatar
Yep. Been working ok so far. I wish I could get the dirty grease out, but hey my bearings wont ever run dry on grease.
I will continue this till they go bad.
So who knows...
Carey
Old Jan 24, 2010 | 09:19 PM
I bet you'll be ok with the moog joints.
I wish the price would come down a bit on the heavier duty versions
Old Jan 25, 2010 | 06:42 AM
Jpurkey's Avatar
what is this greasing the wheel bearing through the abs sensor you speak of? do you just take the sensor out and pump it full of grease? ive never heard of this.
Old Jan 25, 2010 | 07:42 AM
Just need to remove the the allen screw that holds the abs sensor to the hub. Once removed it gives you access to the bearing. I just used a grease needle to inject some fresh grease into the hub. There been alot of talk about this through the forums.
Old Jan 25, 2010 | 03:58 PM
bb45's Avatar
thanks 4 the idea we have 4 3500s with 9.2 boss vs on them and grease thru the abs sensor will be part of the service from now on might even make up a fixture with a grease fitting to screw on thanks
Old Jan 25, 2010 | 04:58 PM
BigDave12768's Avatar
Couple things that may not have been mentioned. Do you tow real heavy? Do you have a heavy body on the back? If the front end of truck is up in air when towing or the weight you carry this will wear out ball joints fast. So if you have these issues. Maybe a set Timbrens or Super sprins for rear
Old Jan 28, 2010 | 03:10 PM
2500's Avatar
sure wish this could be done with 12V
with some folks reporting 330k miles of service from their joints ... doesn't match with folks saying under 50k miles of service even when kept full of grease.
KirtW
The Tire Club
0
Mar 20, 2012 11:44 AM
DodgeDiesel61
Dec 21, 2010 10:21 AM
steerjock
19
Sep 20, 2007 08:13 AM
kscott9564
Jan 5, 2007 08:37 AM
AK RAM
21
Aug 1, 2005 12:16 AM
