Who has the best water pump? Codes ????
tonight we heard a weird noise in the engine and pulled over to check it out. it look like the pulley on the waterpump is loose according to the diagram. if this is the water pump how much to replace it? and how hard is it to do myself? also some codes came up. P 0602, P 0483, P 2509
Just remove the belt and two bolts and out she comes. Cost depends on where you get it. Carquest wanted $80 for a reman, Cummins wants $140, and the dealer, something like $200. If your coolant has over 100k, might as well do a coolant system flush.
P 0602, powertrain control module programming error.
P 0483, fan performance
P 2509 ecm/pcm power input signal intermittent
I had bad luck about OEM Bosch pump from RockAuto:
http://www.dodge.harjutie15.com/copp.../album=62.html
New pump installed, and when running engine warm pulley loose, as you can see. Serpentine belt went broken, also fan has some damages...
RockAuto take guaranteed for the pump very good! They shipped newones at once even here in Europe, but all extra work and fluids etc. I must pay again my own.
I Don't mean that it was RockAuto:s fault, but new parts may broken as old ones....
Hey how do you get the belts off. I was trying to find the spring and cant find it for some reason. thanks for anwsering questions so fast. A mechanic wants to charge me $400 to fix the water pump but that seems to high.
Looks like I have developed a leak at the water pump myself. After staring at it for a little bit how hard will it be to change? For 1 thing it looks like I have to remove the alternator to get to it. But after that it doesn't look to difficult. Or am I mistaken.
Crallscars
16
Jul 25, 2012 04:59 PM
exwrestler
Feb 5, 2010 09:34 AM
roxxx
Sep 24, 2009 08:17 PM
sallyman1
Aug 26, 2008 06:20 PM
