Whining Noise
Old Dec 4, 2006 | 11:51 AM
Laymond's Avatar
Whining Noise
Switched to synthetics over the summer, now the temperature drops down to 10 deg (F) and I have a whine when I let off of the go pedal. Not sure if it is trans or rear end. Is this normal given the temperature? I went with Vavoline at the weights rec by Dodge.
Old Dec 4, 2006 | 12:13 PM
dodgezilla04's Avatar
welcome to dtr. please use the user cp(top left) of your screen and fill out your sig so we know what we are dealing with. year, trans, 4x4?, long bed, etc. it makes a difference.
Old Dec 4, 2006 | 01:24 PM
Laymond's Avatar
2005, 4x4, 3:73 long box.
Old Dec 4, 2006 | 01:30 PM
TexasCTD's Avatar
Might be the U-Joints causing the whine. If so, just replace them with some good greasable units.
Old Dec 4, 2006 | 02:36 PM
since it is a long bed, it has a carrier bearing on the driveshaft. while you are looking at the ujoints, check the bearing, possibly it is going bad, or something may be caught in it. i found a ratchet strap caught on mine, and polished up the driveshaft. it wasnt my strap, wonder where it came from?
Old Dec 4, 2006 | 07:06 PM
patriot dodge's Avatar
I had a carrier bearing go out on mine which made that whine noise right behind rear door, dodge replaced for free.
mattbatson
May 1, 2007 08:30 PM
D.S.
Dec 18, 2006 05:14 PM
SolarExpress
Jul 16, 2006 12:01 PM
Firefighter22
Apr 11, 2005 06:03 PM
