where's the Schrader valve?
Old Jan 17, 2015 | 06:46 PM
DryCreek's Avatar
OK, just wondering if there is a Schrader valve somewhere between the lift pump and the injector pump on the CR system. I had my fuel pump pressure tester out today checking the lift pump on my truck, and I thought that it wouldn't hurt to check fuel pressure on the filter-mounted pump on my wife's truck*. Well, I expected to see a Schrader valve somewhere, but I couldn't find one. I traced the fuel line from the filter to the CP3 pump and didn't see one. On the VP-44 setup, there is a Schrader valve on the inlet side of the fuel filter. That makes checking lift pump pressure very easy. Of course, since the lift pump is mounted on the inlet side of the filter, I would expected the test port to be somewhere else - like at the inlet to the common-rail injection pump.
Can anyone help me out here?
Thanks in advance.
* Less that 12K miles on replacement pump - spare in toolbox. Not changing to in-tank setup!
Old Jan 17, 2015 | 08:09 PM
MikeyB's Avatar
No schrader valve or test port on the common rail models. You can add a banjo fitting at the CP3 for a remote pressure gauge for monitoring the low pressure side. Schrader valve from Geno's Garage. '89-'09 Dodge Cummins Fuel Pressure Test Adapter-Geno's Garage
Here's my setup. I bought the banjo fitting at Geno's Garage. Steel Tapped Banjo Bolt - 3/4 SAE Fitting-Geno's Garage
Old Jan 18, 2015 | 11:26 AM
DryCreek's Avatar
Thanks!
That Schrader valve equipped banjo bolt is probably just like the one on the inlet to the filter on my '01. I think I'll order me one of those.
NCTURBOS
Jan 14, 2007 03:21 PM
I PASS GAS
14
Oct 2, 2006 05:02 AM
D2 Cat
Sep 26, 2006 07:22 AM
CTD2001
13
Jun 2, 2005 03:33 PM
chucktownsend5
Oct 26, 2004 10:03 PM
