Where to install oil pressure sensor?
Old Apr 30, 2010 | 07:15 AM
papaduck's Avatar
I want to install an engine oil pressure guage.
I have a maintenance manual on disk but it does not show the location of the oil pressure switch. (no picture)
Where is the oil pressure switch located? Should I tap into this location with a tee or is there an other location on the engine that I can get a good oil pressure reading without removing the oil pressure switch? The switch seals with a O-ring and it may require an adapter to install a tee.
Old Apr 30, 2010 | 07:52 AM
rufushusky's Avatar
There is a port right on top of the oil filter housing. I would use that.
Old Apr 30, 2010 | 08:16 AM
6 Shaker's Avatar
Or you can pull the plug on the drivers side of the engine just a hair back of the CP3. I'll try and find a pic to post.
Old Apr 30, 2010 | 12:19 PM
papaduck's Avatar
Thanks guys.
The plug on top of the oil filter mounting plate and on the center line with the oil filter will be a perfect place to attach a hydrolic line to mount the sensor on the firewall to get it away from engine vibrations.
The line is being made for me at NAPA.
Papaduck
Redlinear
Feb 14, 2013 01:10 PM
Bobcat698
Mar 25, 2008 09:42 AM
QWKRTNU
Sep 26, 2006 10:22 PM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
