Where to install fuel pressure switch.
Old Mar 3, 2010 | 01:21 PM
robert78.5's Avatar
Where would a person install a fuel pressure switch for gauge on a 2004? I am helping a buddy out.
Old Mar 5, 2010 | 11:41 AM
robert78.5's Avatar
Is there a port near the lift pump?
Old Mar 5, 2010 | 12:04 PM
AH64ID's Avatar
You want the sender (senders are for gauges, switches are for lights) between the last filter and the CP3.
A simple tapped banjo would be the easiest.
http://www.glacierdieselpower.com/pr...x?pf_id=3414TB
Old Mar 6, 2010 | 07:49 AM
robert78.5's Avatar
What should the pressure reading be? My manual only shows up to 2001. Thanks
Old Mar 6, 2010 | 07:56 AM
AH64ID's Avatar
Which LP does he have?
Canister mounted: I am not sure what it will read at idle/WOT.. but should try to stay above 2.
In-Tank: Idle 8-9, cruise 7-8, WOT 5-6 depending on mods. 2 is as low as he should let it go.
Bosch specs are -5 to +15, but on a 0-30 psi gauge you start to lose accuracy around 1-2 psi, which is why I say 2 should be the bottom end, its all you can really accurately tell for low pressure.
hoot
Mar 14, 2011 04:43 AM
mudwisr2
Sep 25, 2007 07:04 PM
QWKRTNU
Sep 26, 2006 10:22 PM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
