What's it Worth?
What's it Worth?
this is an early 04' cummins diesel 6 speed 2 wheel drive, with 121,000 miles on it. the only things i have had to replace is my number sixth injector went out and then about 6 months later my lift pump. the first thing i did when i started doing things to it i went with the bullydog rapid flow 5'' exhaust and egt, boost and oil pressure gauges. it also has a south bend con F E clutch 550hp/1100flbs torque you will not wear it out. i've run the bully dog triple dog in it. it also has the AFE stage 2 cold air, boost elbow, and i made my own intake manifold. i also had the windows tinted to 5% and the front windshild is 30% and the only dent in the back driver side bumper but its nothing deadly i just dont have a picture of it and the tail gate needs to be replaced and the tires are pretty worn out
Try Edmunds
Take a look at this site to get an idea. I put in a basic 2004 SLT 4WD 2500 it gave me from about $11K to $15K... You can adjust options. There are some other "bluebook" sites that can give you an idea too.
http://www.edmunds.com/used/2004/dod...6/options.html
Cummins2fast
Jan 19, 2003 09:43 AM
