Whats the torque sequence for injectors/tubes?
Old Feb 8, 2009 | 07:50 AM
sallyman1's Avatar
when i goto put my injecors back into my 2004.5 what is the sequence? do u first drop injector in and roughly point nozzle hole towards tube hole? then put tube in snugly and make sure u watch injector to see if it straightens out? then snug injector hold down? then give tube final torque? what are the torque specs or procedure for this? i dont have it in my haynes manual.
Old Feb 8, 2009 | 07:54 AM
sallyman1's Avatar
also under my valve cover i noticed 1 spring stuck in the hole. whats the spring for? the spring is roughly 1/2" by 2 - 3 inches long.
Old Feb 8, 2009 | 08:15 AM
djbikeman's Avatar
The complete injector removal and installation process and instructions are here -
http://www.dynomitediesel.com/user_p...html?page=Tech
Old Feb 8, 2009 | 08:23 AM
sallyman1's Avatar
thanks. heres a pic of my engine with cover off
Old Feb 8, 2009 | 09:27 AM
sallyman1's Avatar
thanks again. that manual is awsome djbikeman
Old Feb 8, 2009 | 09:43 AM
djbikeman's Avatar
No problem. From what I have read here, most guys don't remove the rail like it shows in those instructions. They just pull the connector tubes.
My injectors are going to Don in 2 weeks, so I have been doing a lot of searching and reading too.
Old Feb 8, 2009 | 03:07 PM
sallyman1's Avatar
yeah i was thinking that. but im sure i have to remove air horn am i right?
Old Feb 8, 2009 | 08:02 PM
djbikeman's Avatar
I'm pretty sure you need to remove the intake horn and grid heater to get at the connector tube running underneath it. Someone else could verify that. I have read that if you pull the intake horn/grid heater that yo ushould replace the gaskets with new ones.
Old Feb 8, 2009 | 08:04 PM
sallyman1's Avatar
sure thing. thanks
Old Feb 9, 2009 | 03:16 PM
zuki_dan's Avatar
Yes, you have to remove the intake heater to get the #2 connector tube out. Normally when we replace injectors we remove the rear engine lift braket and put a washer on the stud to space for the inj. line brace.
1. I normally tighten all injectors to 42 in/lbs.
2. Install connector tubes with the ***** facing straight up, install nuts and torque to 420 in/lbs
3. tighten all injectors down to 89 in/lbs.
MrExtreme
Nov 20, 2007 08:06 AM
ct2500
Jun 21, 2007 04:34 PM
inline6power
May 12, 2006 07:56 PM
fordsux8269
Jan 2, 2006 01:25 PM
Dufrain
16
Mar 1, 2005 12:51 PM
