whats the proper fix??
Old Jan 28, 2011 | 10:56 AM
zethtays's Avatar
changed out the injectors in the work truck which has had injector issues before but was under warranty then, while pulling the original set noticed that one of the hold down bolts was extremely loose so i just assumed that the dealership that did the work last time failed to tighten it. replaced the injectors with a reman set and when going back tghteningdownhold down bolts the number two injector would never tighten, the bolt started just fine but did feel loose so i tried to clean the threads back up with a tap but the there wasnt anything left thread wise on the head what would be the proper fix for this
Old Jan 28, 2011 | 11:28 AM
.boB's Avatar
Either a Timesert or Helicoil thread repair. Will be just as strong as the original threads.
MikeThomas
Dec 26, 2007 11:34 AM
dieselfuelonly
Nov 13, 2007 08:54 PM
smokeum99ta
Feb 19, 2007 11:11 AM
dieselfan
Jan 23, 2007 06:26 PM
dieselfan
Nov 11, 2006 06:44 PM
