whats the diff between 48RE and 47RE?
Some people burn up transmissions, some people don't.
On a side note, I have a friend that when he tows I feel sorry for his transmission... Kinda hard to say something so I just cringe until I have to say something
. You don't have to drop 2 gears up every overpass and gas it like it's unloaded from every stop light. Driving through houston the transmission has to change gears 1000 times
wow a lot of myth out there about the 2 trannys. like stated not many hard parts were changed to make it stronger. the lock up stage was sped up by opening up a bleed off passage in the separator plate in the vb. same could be had by drilling a .080 hole above the switch valve(small valve behind the retainer), in the valve body itself. disassemble 46re and 48 re and you will see what I am refering too. they opened the plate allowing the fluid to bleed off faster so the converter locks up faster. what do I know I only built vb's for chrysler about 7 years. longer life of the shaft may be contributed to have it peened by an outside vendor. they were cut the same that is for sure.
Since you know that (and I know that), how about posting the 48RE specifics over the 47 from a 'official' DCX standpoint incl -
increased capacity direct clutch drum
3@ 6 pinion planetaries
increased capacity sun gear shell
increased capacity overdrive clutch
ect.....................
So, yeah - what do you know that we don't, eh?
I can not get engineering to give me a number so I will not for sure. official never. dcx is now history the offcial statement would be chryslers stand point.
https://www.dieseltruckresource.com/...d.php?t=182942
BRayls - I merely meant for you to post any upgrades and improvements besides the ones you and I have already listed - anything else that makes the 48RE better and more reliable than the 47R series - excluding the all electric valve body, of course.
97CTDRAM
0
Jun 1, 2012 11:24 AM
VaultRam
Jan 18, 2011 07:35 PM
Dazed&Confused
Feb 22, 2007 05:11 PM
danimal 95
Oct 10, 2006 10:43 PM
j
Sep 26, 2003 11:03 AM
