what oils
Old Sep 12, 2011 | 03:26 PM
brant914's Avatar
what oils
what engine oil, manual tranny oil, differential oil, fuel filter, etc do you guys recommend for a used 2003 with 132,000 miles that I have just purchased used?
Old Sep 12, 2011 | 04:06 PM
Gatorama's Avatar
If you do a "search", you will find hours of reading on these. Congratulations on the new truck.
Old Sep 12, 2011 | 04:12 PM
brant914's Avatar
Thanks I'm definitely excited about the truck.
I did a search and read for quite a while
but the search pulled up so many threads that were not quite answering my questions.... things like "oil leaks" and "differential problems or failures"
after an hour of reading I didn't feel like had any of my questions actually answered, so I thought I would ask the question directly of the experts.
I'm new enough to diesels that I want to get the right products when I go to NAPA tomorrow to buy all of my supplies.
thanks
brant
Old Sep 12, 2011 | 05:23 PM
Sur5er's Avatar
Start with the known commodities:
Shell Rotella 15W40 dino oil
ATF+4 for Auto tranny, power steering (WallMart brand is fine)
GL5 for both front and rear diffs, I use Synth 75W85
Remember to grease the front driveshaft if you're 4X4
DOT4 Brake fluid
Go with Baldwin or Donaldson filters
The more info you post on your ride the easier to help
Old Sep 12, 2011 | 05:26 PM
brant914's Avatar
DOT4 Brake fluid
Awesome
thank you Dick
any recommendations on tranny grease for a manual?
and your filter recommendation is that for fuel or oil filter
the truck isn't delivered yet but is a 2003, 2 wheel drive longbed, with a 6speed manual tranny and high out put motor. its got 132,000 miles on it.
brant
Old Sep 12, 2011 | 07:54 PM
railroaderone's Avatar
use penzoli synromesh in the nv4500
Old Sep 12, 2011 | 08:11 PM
C Schomer's Avatar
But he doesn't have a 5 spd - plus the 5spds call for 75w90. But that would be good to try in the 6 spd. That's the same truck as mine except for 2 less wheels. I've had the best luck with RP synchromax in my 6 spd - better than dodge stuff or amsoil. RP maxgear has been the best in my diff for keeping the wear metal off the magnet and also the best UOAs. I use 85w140 cuz of the heat, here. 75w140 would be fine, elsewhere. I even use RP in the PS pump. Flip a coin for engine oil - use 15w40 diesel rated. I use Schaffer 7000 semi syn in the engine. It's cheaper than full syn and the UOAs are as good as any full syn I've used. A lot of 03s were shipped low on diff lube, the dealers didn't catch it on there new vehicle inspections and dodge got to warranty a bunch of them. I think mine might have been one of them but was caught before it was totally toasted. Mine only had 25k when I got it and the rear ends brgs were all down to less than the minimum preloads. It's stiil doing fine, tho. Mine has been a great truck. One t-stat 28$ and one APPS $169. The 4.10 R&P rocks for towing and I just filled up today... 21.6 mpg (actual), mostly city. The hvac dampers is the only thing wrong with mine right now - a 3rd gen problem. That can wait til winter. Craig
Old Sep 13, 2011 | 07:11 PM
Sur5er's Avatar
Originally Posted by brant914
Awesome
thank you Dick
brant
That would be both! BTW, it should read 75W90 on the synth GL5. Not familiar with "tranny grease".
Old Sep 13, 2011 | 07:44 PM
brant914's Avatar
ha... yeah... I need to not call it that. Its what my grandfather used to call hypoid straight 90 wt back a long time ago...
thanks again everyone for all of the recommendations
I missed NAPA today, but going to go there as soon as they open in the morning and do some shopping. Truck is delivered friday and I'm going to spend the weekend servicing everything!
thanks again
I'm really excited for my first drive
brant
Old Sep 14, 2011 | 05:35 PM
brant914's Avatar
do you add a limited slip additive to your royal purple rear differential?
brant
Old Sep 15, 2011 | 08:29 AM
Sur5er's Avatar
I'd look at adding a remote fuel filter set-up as one of the first orders of business. Somewhere in the forum is the article w/pics that I posted when I fabricated mine. Injectors are VERY expensive for the CR and it doesn't take much to screw 'em up. I think the total cost for the remote set-up was under $125, including both filters and mounts! That's less that 1/3 the cost of a new stock injector
Old Sep 15, 2011 | 09:15 AM
brant914's Avatar
thank you
I'll start a search on remote fuel filters
any good (yet affordable) brands I should look at?
ramlovingvet
Sep 10, 2003 07:46 PM
finallydiesel
Aug 9, 2003 08:22 PM
azjeff
Jun 29, 2003 10:57 AM
Hoss
Jun 20, 2003 08:01 AM
