What material are 5.9 exhaust valves made from
Old Dec 10, 2013 | 12:55 PM
tmc_31's Avatar
Hey guys,
Anybody know what material (alloy) the exhaust valves for the 5.9 engines are made from? Are they solid valves or sodium filled?
Thanks,
Tim
Old Dec 10, 2013 | 02:29 PM
madhat's Avatar
Administrator/Jarhead
From an 04 manual:
"The valves are made of heat resistant steel and
have chrome plated stems to prevent scuffing. Each
valve is actuated by a roller rocker arm which pivots
on a stationary lash adjuster. All valves use three
bead lock keepers to retain the springs and promote
valve rotation."
Old Dec 10, 2013 | 05:24 PM
tmc_31's Avatar
Originally Posted by madhat
From an 04 manual:
valve rotation."
Thanks madhat, have you ever cut one apart? Are they hard of soft? The reason I am asking is that a fellow on another forum is grinding these valves into boring bars for use on a lathe. I asked him what material they were made from and he didn't know. I couldn't find an answer easily on the internet so I thought I would ask here.
Tim
Old Dec 10, 2013 | 07:15 PM
tantruck's Avatar
Should work fine for turning and boring aluminum and soft steels.
Some reading here ---> http://www.underhoodservice.com/Arti...nd_alloys.aspx
Old Dec 11, 2013 | 09:01 AM
tmc_31's Avatar
Thanks tantruck, good reading. Lots of info on valve design. Thank you for the help. I think the guy on the other forum may be on to something. I am going to find an old valve and give it a try as a boring bar.
Tim
427AC
Jan 22, 2005 10:05 AM
gottahavediesel
Oct 15, 2004 08:56 PM
popeye
Dec 8, 2003 10:33 PM
AKDSLDOG
Nov 7, 2003 07:55 PM
