What do these do...rokktech sensor and tone ring?
Old May 23, 2007 | 04:19 PM
Rollin' Smoke's Avatar
what do these things accomplish and what are the gains? i would really like a good explination if someone could help me out! thanks alot
Old May 23, 2007 | 05:56 PM
CTDinMT's Avatar
It will allow you to advance your timing 2 degrees. This will improve your MPG about 1-1.5 mpgs and give a small amount of low end torque. Mine had a noticeable improvement in power when I let out the clutch. It's worth the $70 for the Rokktech.
Old May 23, 2007 | 10:17 PM
is any programmers or boxes that you need to stay way from because of the advanced timing?
Old May 23, 2007 | 11:16 PM
03qclb5spd's Avatar
With the mods in my signature would I be okay running the Rokktech sensor?
Old May 24, 2007 | 06:55 AM
i am new to these things so and I didnt really get alot of info off of their website is why i am asking the questions
Old May 24, 2007 | 07:05 AM
Peterbilt's Avatar
With the Rokktec I feel a little more low end grunt. The tone ring mod accomplishes the same thing. The general concensus is with no chips it provides some benifits. With a chip, some say it advances timing too much, others say no problem. Personally, if I was going with and
Pete
Old May 24, 2007 | 08:16 AM
still not clear on the whole tone ring thing!!!
Old May 24, 2007 | 08:24 AM
vzdude's Avatar
DTR's 'Go to Guy'
Timing is changed with the roktech. It moves the postition that the sensor is actually mounted, therefore changing the timing. Timing is changed to give better performance and MPG. I would not run this with any other mod that changes the timing due to the fact that too much timing can cause serious internal engine damage. If you plan on buying a module or downloader, then make sure what it does before you add it to anything else that mods the timing.
Old May 24, 2007 | 11:21 AM
thanks alot.........i hear that some people are getting moderate gains from just a simple 2degree timing change.
Old May 24, 2007 | 11:42 AM
vzdude's Avatar
DTR's 'Go to Guy'
Sure! I just would go over 2 degrees myself! Good luck.
Old May 24, 2007 | 12:29 PM
you mean wouldnt?
Old May 24, 2007 | 04:11 PM
coparam4x4's Avatar
Is Rokktech the only maker of a timing advancer?
Old May 24, 2007 | 06:38 PM
06megacabman's Avatar
I just bought and installed the Rokktech sensor last weekend. This weekend will be the first time towing with it and my 12K# Toy hauler. Have to say once I installed it and drove around the neighbor hood a bit it did have better low end punch. I don't know about mileage yet, my overhead actually went down by ~1.5mpg but that could be because I kept getting on it to see if I could tell the difference. As far as my research found Rokktech is the only manufacturer. I would recommend it rather than modding the tone ring as the sensor is just easier and quick to install. After the fact if I could have understood the pics on DTR better I would have used a dremel and mod'd my stock one to do the same thing.
Old May 24, 2007 | 07:21 PM
w.tx iceman's Avatar
where did you find the pics at
Old May 24, 2007 | 09:45 PM
rockcrawler304's Avatar
Anybody here with a completely stock truck (like mine) with the rokktech, and did you see any mileage gains?
So far all the people I see with it in thier sig line have other mods as well. I won't be ready for any other mods for about another 3 months but this seems like a nice cheap mod I can do right now.
