what boost readings
Old Oct 18, 2008 | 10:21 PM
rich's Avatar
what boost readings
just put aboost gauge on the truck, what are the readings that are being seen at highway speeds empty with no mods. want to make sur about what numbers i'm seeing. thanks
Old Oct 19, 2008 | 12:59 AM
DieselBoy20's Avatar
It can vary but with no outside wind my truck cruises at 70 around 6-8 psi. With a little wind pushing on you my truck will go up to 15/20 sometimes and then likes to sip the fuel. But i'd say your normal in the 5-10 range if this helps you.
Old Oct 19, 2008 | 12:38 PM
coparam4x4's Avatar
X2............
Old Oct 19, 2008 | 01:00 PM
rich's Avatar
thanks thats what i'm seeing thought it mite be low
Old Oct 19, 2008 | 03:42 PM
Sevir's Avatar
cruising at about 60-65 on flat ground i see about 5-8psi
Old Oct 19, 2008 | 04:12 PM
TriSum's Avatar
The lower the better. Less fuel.
David
xp8103
19
May 20, 2005 08:56 AM
xp8103
15
May 4, 2005 09:12 AM
Barrett_Fodder
May 26, 2004 04:39 PM
tobyw
Dec 6, 2003 11:09 AM
lezmark7
Jun 28, 2003 11:50 AM
