Weird FP readings
Weird FP readings
Hi- I am starting to get some weird readings on my fuel pressure gauge (Commander) such as fluctuating pressure (fluctuating from 0 to 10 psi and everywhere in between). I'm thinking my stock LP is on it's way out? Any ideas? Thanks!
OK- Update: I had the sender for the Commander mounted on the outlet of the FF housing. I figured maybe I wasn't getting a good ground there because the housing is aluminum. I moved the sender to the CP3 (where Quadzilla recommends
) and voila, it's working again. I had mounted it on the FF housing because the sender won't fit at the Cp3 with the Jacobs Brake. I've since decided to get the BD Brake instead, so I'm back in business. I am getting 6 psi and its dropping to 3-4 psi under acceleration, so I'm still think the LP is getting weak. Morale of the story: Quadzilla is smart, I'm not, Quadzilla is good looking, I'm not so much...
duallydave
Apr 10, 2008 10:23 AM
GlennRMK
Sep 5, 2006 11:24 PM
