Weeping coolant!!
Old Dec 17, 2008 | 10:15 PM
D384D's Avatar
Weeping coolant!!
My truck is weeping coolant from the hose that connects the radiator to the overflow. It drips right where the hose slides over the fitting on the back of the radiator, and forms a puddle in the mold of the air box cover. Is there a TSB out for this?
Old Dec 17, 2008 | 10:18 PM
torquefan's Avatar
Never seen a bulletin for that, but I've noticed that connection often gets snagged or disturbed when the air box cover is removed. I've often secured it with a plastic tie-strap used as a hose clamp.
Old Dec 18, 2008 | 07:03 AM
MikeyB's Avatar
Slap a hose clamp on there and you're good to go. It's a know issue with our trucks.
MikeyB
Old Dec 18, 2008 | 07:25 AM
troll3193's Avatar
i put a hose clamp on mine as it has come disconnected a couple of times.
Bryan
Old Dec 18, 2008 | 09:47 AM
dozer12216's Avatar
hose clamp it.
Old Dec 18, 2008 | 09:53 AM
Bigiron's Avatar
After a while the elasticity of the hose weakens where it slides over the bib below the radiator cap. When this happens the connection starts leaking. Mine did it a couple months ago just after I installed my bypass filter. I got under the truck to check for leeks and found a coolant leek instead of an oil leek. Like everyone says, just put a hose clamp on it like the factory should have done in the first place.
Old Dec 18, 2008 | 04:24 PM
D384D's Avatar
Thanks guys. Do you think silicone would help too?
Old Dec 18, 2008 | 10:43 PM
torquefan's Avatar
I don't think I'd bother. The hose clamp should take care of it.
joel
Sep 6, 2004 08:04 AM
Gypsyman
Jun 11, 2004 08:27 PM
redramnc
Dec 8, 2003 02:43 PM
JKE
Oct 11, 2003 12:52 PM
picdodge
Feb 18, 2003 01:52 PM
