View Poll Results: When did your water pump fail?
Never flushed and it failed
76
45.51%
With-in 5k miles of MOPAR HOAT
2.40%
With-in 5k miles of aftermarket antifreeze
4.79%
After 5k but prior to 50k miles of any flush
21
12.57%
After 50k miles of any flush
58
34.73%
Voters: 167. You may not vote on this poll
Water Pump failure poll, when did yours fail?
Old Feb 28, 2015 | 08:28 AM
  #136
DragonSlayer's Avatar
Originally Posted by DragonSlayer
176xxx on the original.
I noticed mine was slobbering again at 193xxx. Now at 195xxx, it is running out on the ground.....
Old Feb 28, 2015 | 08:39 AM
  #137
Reelay's Avatar
Easy fix pump is not expensive. Do a search on here for instructions on how to R/R.
Old Mar 2, 2015 | 02:12 PM
  #138
ez_lle71's Avatar
Just replaced mine at 84,xxx miles last month. I pulled radiator at 50,000 miles or so to blow the grass seed out and changed antifreeze then. I don't drive my truck much but it never got hot and the weep hole on the old pump was crusty and not letting alot of coolant out. no drip just orange staining from belt slinging it around. When i got it pulled out and spun it by hand, no doubt it was shot.
ez
Old Mar 3, 2015 | 10:40 AM
  #139
pdogg's Avatar
just changed mine out @130k with the Geno's Garage version (gates I think)... I did it as preventative maintenance, when I replaced the entire cooling system, hoses, pump, thermostat, pulleys, belt ..etc..
I had no leaks, but I was running hotter than normal..
Old Jul 15, 2015 | 10:14 PM
  #140
XxFishxX's Avatar
My '01 started leaking last week at 139.2k, but to be fair I was hauling a dump trailer with about 10k+ of dirt. All day. 22 m round trip so 11 m loaded running 70 mph about half the trip and 55 mph other half. Also have my welding rig up on it too. It hasn't failed just leaking. Hopefully it holds out till next week when I get a week off.
Old Jul 16, 2015 | 09:48 AM
  #141
Chip's Avatar
Original pump went at 82k, replaced by dealer. Second went at 160k replaced by me.
Old Aug 6, 2015 | 10:56 PM
  #142
diesel yukon's Avatar
mine went out at 130,645 took me an hour to change. I wish I could find an electric one like I put on my 12 valve.
Old Oct 7, 2015 | 09:43 PM
  #143
Humblecowboy's Avatar
88k and it leaked briefly today so I stripped hoses and flushed radiator. Replacing all hoses, pump and T-stat. My service manual states 24 qts. of coolant. That can't be right. Ain't that like 8 gallons? I only drained about 3 gallons when I pulled the hoses. Haven't pulled the T-stat yet so maybe there is more in the block but shoot, can't be that much. I only bought 2 gallons of anti freeze.
Old Oct 7, 2015 | 10:37 PM
  #144
seafish's Avatar
Well 24 quarts is "only" 6 gallons, but a couple gallons or more stays in the block even after flushing. You need to account for what is in the block as water and add concentrate to match it for a 50/50 ratio.
Here is an excellent how to with pics--
Coolant flush on a 3rd Gen. - Dodge Cummins Diesel Forum
Old Oct 7, 2015 | 11:20 PM
  #145
Well seafish that's what I get for using Jethro's ciphering method. Why I was thinking 8 gallons I don't know. Not only was I suspecting some left in the block, I never got the radiator drain plug to flow when I turned it 90 degrees left so there is still some in the lower part of the radiator. I back flushed it out the inlet hose nipple and tomorrow am going to flush the inlet side by stuffing a flexible hose in it and pushing the contaminates up and out. Thanks for the correction and the info on the block. Once I pull the pump more will come out of the block I hope. Gotta get more antifreeze tomorrow. :-(
Old Oct 9, 2015 | 05:51 PM
  #146
bobsallyh's Avatar
'03 with 197,000 on the clock, still on the original. Changed out the original anti-freeze at 98,000 with the Zerex HOAT. I do carry a spare.
Old Oct 12, 2015 | 12:19 AM
  #147
Is it just the 5.9's that have this water pump problem? I see in this thread their we're only 3 or 4 guys with 6.7. Do the 6.7's have better pumps on them?
Old Dec 10, 2015 | 12:06 AM
  #148
Vanegam1's Avatar
200,000 still going
Old Dec 10, 2015 | 04:07 PM
  #149
LarryM's Avatar
Just changed mine out at 100,189K after it started marking the garage floor. Did a complete flush plus a new T-stat. Pump from Geno's, T-stat and Zerex HOAT from Napa, distilled water from wallyworld.
Old Dec 10, 2015 | 09:59 PM
  #150
SolarExpress's Avatar
100,934 the first time...second at 256K.
