Water in Fuel 03, 04 and 05
Old Jan 31, 2005 | 08:07 PM
  #31
Welder's Avatar
Ok if this works you can see a white one at the right of the pic and a black one to the left on the other side of the cross member. I had to shrink it down but I think its still a good pic of what we are talking about
Old Jan 31, 2005 | 08:19 PM
  #32
TCBnc's Avatar
Welder,,,, Yea,,,Great Picture..... They said they were going to run a hose from each fitting and T it off in the middle. Then run the bottom part of the T down between the Tank and Muffler heat Shield close to the Tank. I can see how they would do that from your picture. Man......This truck in the picture must of really got alot of water in it without a Bed over the tank.
Thanks TCB
Old Jan 31, 2005 | 08:23 PM
  #33
tfarmer96's Avatar
Is it just me or does this hack all of you off. I mean give me a break they put a tank that allows water in on a 4X4 and expect water to never eneter the tank!
COME ON DC
Water in Diesel!!!! Here is the simple equation for that
WATER+DIESEL …….HOSED=YES
Sorry for the rant guys i couldnt help it.
Old Jan 31, 2005 | 08:25 PM
  #34
TCBnc's Avatar
tfarmer96
I think from what I read , IS That they have to vent. So I would not Plug them.
TCB
Old Jan 31, 2005 | 08:27 PM
  #35
tfarmer96's Avatar
TCBnc
you have a good idea with the T connector. First chance I get I will rig mine up just as you described.
Old Jan 31, 2005 | 08:34 PM
  #36
Welder's Avatar
How many are out there with water and a big $bill from the dealer.With no knowledge of this
problem!!!!!!!!!!!!
Old Jan 31, 2005 | 08:56 PM
  #37
Geico266's Avatar
problem!!!!!!!!!!!!
Welder, I have read of several problems of excessive water in 03, 04 CTD on other sites. I will post the info there also with a link to your pics. I'm sure more owners will respond in a few days.
I have a question. What keeps fuel from coming out of the fitting on fillup?
Old Feb 1, 2005 | 04:12 AM
  #38
Welder's Avatar
I don't know if its a check valve or why fuel doesn't come out. I read on one post, and the guy got a lot of ribbing for his wording. He said he could suck and or blow air through the nipple
Old Feb 1, 2005 | 04:26 AM
  #39
v8440's Avatar
You got me a bit paranoid now. I don't make a habit of going 4 wheeling in mud and water, but sometimes I have to. Is this something I can check for w/o pulling the tank? I have access to a lift if that would help.
Old Feb 1, 2005 | 10:00 AM
  #40
Geico266's Avatar
I'm pretty sure you can get under the truck and see it with an inspection mirror and a light. A lift would make it alot easier.
Old Feb 1, 2005 | 06:00 PM
  #41
B Proctor's Avatar
Just run your hand up there, you'll be able to tell. Mine's '05, I'll be making up a "T" type vent assy tomorrow asap. Thanks Welder
Old Feb 1, 2005 | 07:19 PM
  #42
ed paul's Avatar
and to think i was getting underbody flushes at the car wash!!!!!!!!!!!!!!!!!!
now i know why my truck idles like crap eveytime it even gets near 32 degrees outside,,,,,,,,,,,,,,if there is water in the tank, how do i get it out? will it run out eventualy? or are we talkin a $1100 flush?
thanks WELDER !! i hope good things happen to u for the rest of ur life!!
Old Feb 1, 2005 | 07:23 PM
  #43
ed paul's Avatar
and thanks for the pics guys!! ur all sure jumping on the,,,,"that"s cool"
Old Feb 1, 2005 | 07:24 PM
  #44
ed paul's Avatar
sorry,,,jumping on THIS " that"s cool"
Old Feb 1, 2005 | 08:14 PM
  #45
Welder's Avatar
I drive about 100 miles a day. I would drain the separator when I got to work and when I got home, as I started seeing less water I went to once a day, then every tank.
