vin number
Old Mar 28, 2006 | 04:09 PM
StrokeThis2500's Avatar
vin number
anybody wanna run my vin for me 3D7KU26C84G133994 tell me everything possible rear end all that good stuff if u can thanks guys
Old Mar 28, 2006 | 05:47 PM
Robert P's Avatar
Repair Date Dealer/Payee Claim
Number
Repair
Odometer
List
Date
Transaction Type
January 31, 2006 45212 - JIM JARD DODGE
19700110 - Pump, steering-Diesel engine
130089 59,325 Miles 2006022 SERV CONT REPAIR
February 28, 2005 43366 - CLEAR LAKE DODGE
14302015 - Injector, fuel-One, all others
037594 36,415 Miles 2005032 WARRANTY REPAIR
February 28, 2005 44433 - BONHAM CHRYSLER W84965 36,068 Miles 2005031 X REPAIR
January 20, 2005 26410 - ELLIOTT MOTORS
19630103 - Tie rod end-Inner/outer-Right
054295 33,667 Miles 2005014 WARRANTY REPAIR
October 18, 2004 44433 - BONHAM CHRYSLER
02106512 - Ball joint, front upper and lo
212699 25,477 Miles 2004104 WARRANTY REPAIR
August 25, 2004 67808 - BURGDORF AUTO CENTER INC
02200101 - Stabilizer/sway bar, front
006606 20,958 Miles 2004092 WARRANTY REPAIR
October 30, 2003 44433 - BONHAM CHRYSLER
85900040 - Road Ready-Basic Prep
PREPNV 0 Miles 2003111 PREP REPAIR
lots of front end repairs
this is what i found on dealer connect
Old Mar 28, 2006 | 05:57 PM
TRAVIST's Avatar
PM me a fax number and I'll send you a copy of all options on your vehicle.
Travist
Old Mar 28, 2006 | 06:42 PM
Robert P's Avatar
Vehicle Option - All
Standard Equipment
Code Description Code Description Code Description
APAS Monotone Paint BAZS 136 Amp Alternator BRTS Anti-Lock 4-Wheel Disc Brakes
CGDS Front Height Adjust Shoulder Belts CGZS Passenger Air Bag On/Off Switch CG1S Next Gen Multistage Front Air Bags**
CKES Floor Covering Carpet CLAS Front Floor Mats CSPS Passenger Assist Handle
CUSS Overhead Console w/Trip Computer CU3S Behind the Seat Storage / Bin DBBC All Manual Transmissions
DH1S Man Shift-on-the-Fly Transfer Case DJQS 5,200# Front Axle DMES 3.73 Axle Ratio
GACS Tinted Glass Windows GJDS Rear Fixed Window GNMS Passenger Side Sun Visor w/Mirror
GVBC All Vehicles W/Power Mirrors GXMS Remote Keyless Entry HAAS Air Conditioning
HGBS Dash Liner Insulation HGFS Floor Tunnel Insulation I77S Route 77 - UP, Mesquite, TX
JAYS Instrument Cluster w/Tach JCBS 120 MPH Primary Speedometer JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter JJBS Dual Note Electric Horns JJJS 12V Auxiliary Power Outlet
JPBS Power Locks JPDS Power Windows, Driver One-Touch LBCS Glove Box Lamp
LMAS Halogen Headlamps LPES Cargo Lamp MBFS Bright Rear Bumper
MCMS Body Color Upper Fascia MCTS Bright Front Bumper MDAS Front License Plate Bracket
MFDS Bright Grille MTDS SLT Badge MURS Dodge Badge
MUSS 4X4 Badge MWDS Removable Tailgate w/Caliper Latches MXBS Front Air Dam
NFVS 35 Gallon Fuel Tank NHMS Speed Control NMCS Heavy Duty Engine Cooling
QW7S Bright White Clear Coat RAAC All Radio Equipped Vehicles RBKS AM/FM Compact Disc Radio w/Chgr Ctrl
RCDS 4 Speakers SBES Power Steering SCFS 4-Spoke Steering Wheel
SFBS Front Heavy Duty Shock Absorbers SGBS Rear Heavy Duty Shock Absorbers SHAS Front Stabilizer Bar
SUAS Tilt Steering Column TBBS Full Size Spare Tire TBMS Tire Carrier Winch
TT3S LT265/70R17E BSW All Season Tires WF1S 17 Steel Spare Wheel WGSS 17X8.0 Steel Chrome Clad Wheels
WLYC All Steel Wheels XBSS Pickup Box XFUS Trailer Tow w/4-Pin Connector Wiring
YAAS Build To U S Market Specifications 1AAS U.S. Dealer Retail 163S Zone 63-Dallas
5I4S Four Wheel Drive (4WD)/(4X4) 5ZFS 8 FT. Cargo Box 5ZJS Regular Cab
5ZMS 2500 GVW 5ZWS DR-Vehicle Family 594S Vehicle Order Tracking
6USS Label - U.S. Specifications 644S Texas State Code 944S Texas State Code
Optional Equipment
*V9 Cloth 40/20/40 Bench Seat -L5 Taupe A50P 5.9L TD HO Eng(ETH)/6Spd M/T NV5600
BCQP 750 Amp Maintenance Free Battery CBEP 40/20/40 Split Bench Seat DEE 6-Speed HD Manual Transmission
DRQP 11.50 Rear Axle DSA Anti-Spin Differential Rear Axle ETH 5.9L HO Cummins Turbo Diesel Engine
GNK Rear View Auto Dim Mirror GPG Power Trailer Tow Mirrors, Fold-Away K1XP JET BLACK - Molding - Bodyside
K17 Bodyside Molding MXCP Front Air Close Out Panel NAA Federal Emissions
NZCP Current Generation Eng Controller PW7A Bright White Clear Coat RDDP Fixed Long Mast Antenna
TZHP Michelin Brand Tires WMJP Center Hub XZAP Speed Control Type
YEP Manuf Statement of Origin YHBA 8 Additional Gallons of Diesel Fuel ZEJP Spring - Left FrontSpring - Left Rear ZTHP Spring - Right Front ZVRP Spring - Right Rear
Z7CP GVW Rating - 9000# 2BG Customer Preferred Package 2BG 2TGA Customer Preferred Package 2TG
3VTA Customer Preferred Discount 3WLA Regional Discount 4KZP 4X4 Tracking
5A6P Waterbase Paint 5B3 Cargo Box Tracking 5TV BusinessLink Inventory
5TX BusinessLink By-Pass 6FA Paint Order Code
Dealer Installed Option
XERA Towing Ball Hitch For Trailer 7SAA SIRIUS SATELLITE RADIO
here is the options list for your truck
Old Mar 31, 2006 | 04:55 PM
thanks guys anything else is there any way to find previous owner info thanks
Old Mar 31, 2006 | 09:25 PM
Robert P's Avatar
i can get his name but i think that is it. ill have to check.
Old Apr 1, 2006 | 12:03 PM
bekim's Avatar
Robert can you run a sevice history for me 3D7KA28C04G174934.
Thank you sir. I went in for 18-037-04 reflash and they said I had the latest, but I've never had a relash. Just wanted to see what they pu in the record about it! Thank you!!
Mike
Bowser50
Jul 26, 2009 07:22 AM
00turbo
Jun 16, 2004 08:26 AM
jarmar
Jan 14, 2004 03:08 PM
alvinator
Mar 18, 2003 08:58 PM
KenR
Dec 18, 2002 02:11 PM
