Vibration---- U Joints?
Old Jan 30, 2015 | 08:32 PM
rockcrawler304's Avatar
Originally Posted by Jona Gold
Just food for thought- reading your symptoms, I agree with others that said rotors, calipers, and wheel bearings are the most likely culprits.
But I have been down this road myself (chasing odd vibrations)- so I'll quickly replay what happened here:
Had swapped to a single mass flywheel clutch setup (2nd one in the truck) just like you just did. My issue was different from yours- it was only while the vehicle was NOT moving. At about 1300 and 1700 rpms, there was a very noticeable shake.
At the behest of the installer- I replaced the damper on the front of the crank (which made sense) with the upgraded 6.7L version, and I even swapped the rear drive-shaft, dropping the 2-piece and installing the 1-piece aluminum mopar "upgrade" because I also was noticing a new shudder on take-off. These things made a noticeable difference in smoothing things out, but did not eliminate the odd vibrations at stand still.
Reverting back to an OEM style DMF clutch kit was what finally eliminated my vibration issue. The Dual Mass reduces vibrations in the drive-line by design, and the G56 is designed to have a dual mass in place to do just that. I wouldn't rule out an out-of-balance brand new single mass flywheel. It's rare- but it happens, I was lucky enough to find proof. Also- those added vibrations didn't just cause an annoying "chatter" in my transmission. When I removed my transmission I found my input shaft seriously loose and had to pay to have my G56 get all new bearings, etc. (basically rebuilt).
Running a single mass- I would highly recommend you upgrade your damper (if you haven't already), and consider the one-piece aluminum shaft update as well. The more vibrations you can eliminate from your drive-line, the longer everything attached to it will last.
I have followed your SM back to DM thread. I have zero vibrations at idle or really any other time except for when I let off the throttle and also coming to a stop. I won't rule out brake or related parts but I also do not this it is the problem because I would have had the issue before the clutch. Also the vibrations happen when I am not applying the brakes but still coasting to a stop and goes away instantly if I give it a bit of throttle. I'm finally off work tomorrow so I can do some diagnostics. Starting with the drive shaft orientation. The one piece DS in on my list for sure and after reading more about vibrations I will also do the damper swap as well.
Old Jan 31, 2015 | 08:43 AM
.boB's Avatar
Fortunately, warped brake rotors are not common. Not nearly as common as people think they are.
-Warped- Brake Disc and Other Myths
Seems like these trucks have a problem with the rear calipers locking up, though. That can overheat and warp the rotors. But you can smell it when that happens.
Old Jan 31, 2015 | 05:23 PM
Update
I removed the four bolts at the rear diff to change the orientation of the DS and found that u-joint was locked up in one direction!! Changed the u-joints and vibration is GONE!! The needle bearings in one cap were just dust!
Old Jan 31, 2015 | 07:52 PM
seafish's Avatar
Update
NICE find….thanks for the update.
I'd venture that someone dropped a needle bearing inside that cap when reinstalling the joint and then just forced the cap and circlip on without knowing what they'd done…that would lock it up on one side and def cause a vibration!!
I always check for play and tightness in all directions after installing new ujoints…in fact, after a few "tighter" installs, I started using a bronze hammer to thwack the caps/yokes on each end AFTER installing the cir clips…the blow resets the caps and yokes just a little away from the spider and after doing so there is a noticeable gain in freely turning in what might be a tight turning joint (NOT that was YOUR problem…whoever did the ujpints owes you a least a six pack!!!)
Old Jan 31, 2015 | 08:54 PM
I always check for play and tightness in all directions after installing new ujoints…in fact, after a few "tighter" installs, I started using a bronze hammer to thwack the caps/yokes on each end AFTER installing the cir clips…the blow resets the caps and yokes just a little away from the spider and after doing so there is a noticeable gain in freely turning in what might be a tight turning joint (NOT that was YOUR problem…whoever did the ujoints owes you a least a six pack!!!)
Actually the u-joints were factory! 135k miles But I also use a bronze hammer to do the same as you. I also try to only use my heavy hard plastic ended deadblow hammer when possible.
Old Feb 1, 2015 | 01:45 AM
seafish's Avatar
Actually the u-joints were factory! 135k miles.
oops... missed that part...in any case, glad that you got er fixed.
Old Feb 1, 2015 | 09:12 AM
Steve-l's Avatar
These u joint failures, with the exception of the center bearing angle issue, is caused by the lack of lube. Replacing these factory joints with high quality joints with grease zerks and relubing every 6 mos. solves the problem indefinitely.
shima
May 11, 2011 02:02 AM
driftingfly
May 26, 2009 10:00 PM
JohnnyH
May 14, 2007 03:12 AM
dodgedsl03
Jan 18, 2007 10:08 PM
MedicShawn
Aug 3, 2006 10:39 PM
