Vibration at 65-75mph
Old Jun 20, 2006 | 11:06 PM
cromulius's Avatar
I have a lower speed on and off buzz type of vibration and another at the 70 range that seems more like driving over bumps that makes me think of those cars you see driving around with a broken shock. I am sure none of my tires has that kind of movement but it sure does feel bad.
Old Jun 21, 2006 | 02:44 AM
Hounddog's Avatar
Friend of mines 06 4x4 just had a transfer case bearing done.Was noisey.Seemed to help some but still has a vibration.Its still in the shop.
Old Jul 10, 2006 | 01:30 PM
dzltrqcrzy's Avatar
The hose clamps worked for me as well.
I first had 3 on the rear driveshaft, one on each end and one in the middle.
I dampend the vibe by about 50%. I ran like that for 6+ months, until I read this thread and put 2 on the Tcase side, one on the diff side and none in the middle.
Left them somewhat loose so they could rotate on the shaft as it was spinning kinda like the centermatics on hubs, went on the highway, ran at 70 and the vibe was 95% gone. Removed the one on the diff side, 70 mph, didn't make it better or worse. Went home, tightened the clamps. Done.
Old Dec 27, 2008 | 05:24 PM
sallyman1's Avatar
what u mean hose clamps. can u explain or post pics where u put them? i get a vibration at 60 mph and 1800-2000 rpm.
Old Dec 28, 2008 | 03:01 PM
sallyman1's Avatar
can an1 explain where to put the hose clamps?pics?
Old Dec 28, 2008 | 10:37 PM
dozer12216's Avatar
Originally Posted by bigdav160
Can you describe the vibration? At that speed the vibration is almost certainly tire related. Driveshafts are turning 4x faster than the tires and the frequency (think buzzing) of the vibration at that speed would be very high.
Statement is correct. A vib at 65-70 MPH is most likely a tire issue. A tire at that speed will give a 9-12 HZ vib. You feel your stomach shake or see the hood move. A drive line vibe will be a buzzing feeling. You can generally hear it more than feel.
As tires wear and get pounded by pot holes, the belts move and cause issues that balance will not fix. sometimes you cannot measure a difference in runout, but the tire will have strong or weak areas that act the same as balance.
Old Jan 1, 2009 | 10:21 PM
AEmedic's Avatar
I recently started suffering with the same issues, I took the truck into the dealer and there is a TSB that replaces much of the front steering assy. It seems to have cured the problem and looks to be quite heavy duty. I only have 17k miles so it was covered under warranty.
Old Jan 11, 2009 | 12:23 AM
rbox's Avatar
I had the same vibration, pulled from driveshaft, had it balanced and it is almost gone. You shouldn't have to finish the manufacturer's job on a 40k truck!
Old Aug 15, 2012 | 02:34 PM
slacker 24/7's Avatar
reviving a old thread
SAME HERE !! I posted this in another thread but this one really applied better. Same Vibration as a lot of folks (55-75 or so) After narrowing this down to the rear shaft (one piece) by pulling the front shaft with no diffrence, and replacing the joints with no affect, i had the rear DS balanced by a local driveline shop that does my rock crawlers shafts, he was suprised to see 8 larger factory weights on the stock shaft 4 front, 4 back, he spun it and worked on it for a hour and wound up pulling all the factory weights off and put 3 smaller weights on, 2 in the rear 1 front, he said it had to be out of balance from the factory and said sometimes it has to do with the way they install the ujoints but was unsure if that was the case here as i had already replaced the ujoints with new spicers, I havent ran the shaft yet but there was a very marked improvement with the shaft on the machine it was vibrating pretty bad when i took it in and was running very smooth when he finished it.... hope thats it and will post up as soon as i can get home to run it...
Old Aug 15, 2012 | 03:01 PM
rebal's Avatar
we ended up pulling the front drive line with the yoke off the axle and had it rebalanced that was are issue
Old Aug 15, 2012 | 03:18 PM
wonder why the factory DS balance is off on these trucks so many times??? i put the shaft in and ran it.. FIXED i swear i think thats why the PO sold the truck and i have read posts here where folks replaced the whole dang driveline and a good DS balance fixed the issue...
Old Oct 25, 2012 | 11:03 PM
newwelder27's Avatar
i have the same problem i just bought a truck and it has 65k on it. My vibration is from 70-80 then goes away i do feel it at lower speeds if i really pay attention. I have been searching and searching and found this so hopefully i can get this fixed. If so i will love love love the truck.
Old Nov 14, 2012 | 06:40 PM
banyon's Avatar
My 06 did this for about six months. I finally got sick of it & jacked up the rear & ran it up to 70. It was like it was coming apart. I took out the rear shaft & it stopped. I then put two hose clamps around the shaft. It was worse so I rotated them a little & tried again. It was better. I kept moving them & now its all but gone. I.m going to have it balanced next week.
Old Nov 14, 2012 | 09:42 PM
klx650a2's Avatar
Mine did this until I had the front and rear drive shaft balanced by a good local shop. It was not cheap but I don't have any more vibration.
abc4yew
May 7, 2007 12:32 PM
joe22790
19
Aug 16, 2006 11:22 AM
TexasCTD
Aug 2, 2006 10:02 AM
flstfhog
Nov 5, 2003 07:18 AM
