Vibration at 30 to 45 mph
Old Jul 7, 2008 | 12:40 PM
tls1959's Avatar
2005 Ram 2500 (48RE) vibrates when going 30 to 45 mph. Trans was recently serviced at dealer. Had vibration prior to and after service. Truck has 76000 miles. No vibration at highway speed and vibration is not as bad when in tow/haul mode. Any suggestions?
Old Jul 7, 2008 | 09:45 PM
BigIron70's Avatar
Cummins Guru
I would check driveshaft and ujoints. Do you feel vibration in steering wheel or in your seat? Check for any wobble in drive shaft while on rack. Is truck 4X4? Do you have off road tires?
Old Jul 8, 2008 | 09:31 AM
tls1959's Avatar
Truck is 4x4 and I have BF Goodrich Rugged Trail tires. Feels like truck is vibrating. I plan on having tires rotated and balanced this week.
Old Jul 8, 2008 | 11:55 AM
Hopper's Avatar
Driveshaft and U-joints are a good place to start, as BigIron70 mentioned. I have just finished dealing with the exact same problem. U-joints did not appear to be the problem at first, as they seemed tight. After 5k more miles, it was evident that they were the culprit. About the same milage as mine started to go also.
Old Jul 18, 2008 | 08:30 PM
tls1959's Avatar
Thanks, the center u-joint was bad. Replaced all three u-joints with ones that have grease fittings and had drive shaft balanced. No vibration.
treemonkey
Jun 17, 2009 02:06 AM
Mark Hodowanec
Nov 13, 2004 11:02 PM
Mark Hodowanec
Nov 10, 2004 06:41 PM
hoot
122
Aug 2, 2004 08:38 AM
dieselnewbie
38
Apr 20, 2004 05:57 PM
