Valve Adjustment Gone Wrong!
Old Mar 22, 2010 | 11:21 PM
Diesel87's Avatar
Over the weekend I had my rockers off to install valve springs and injectors. When I adjusted my valves I forgot to turn the engine to TDC. When I started the engine it sounded awful. The engine noise is not a rattle it's more like a popping sound. Would a wrong adjustment cause this problem?
Old Mar 23, 2010 | 12:15 AM
bigwheels94's Avatar
Ummmm. Hmmm.
How did you even get clearance with some of the cam followers up?
Better check for bent pushrods, valve bridges, & valve stems. Might have broken a spring or two also, which could have dropped a valve.
Bad news man.
Old Mar 23, 2010 | 07:29 AM
patdaly's Avatar
DON'T RUN IT.
That popping sound is likely bad juju.
Get it to a Diesel mechanic as soon as possible, Cummins certified would be preferable.
Bigwheels went through most of the things that could be biting you;
Old Mar 23, 2010 | 07:35 AM
rip 112's Avatar
Dang man.....
Old Mar 23, 2010 | 07:39 AM
Jeff in TD's Avatar
I wonder if you set some with the lifter partly up, and ended up with a ton of clearance when the lifter was down if the pushrod came off the rocker or something.
Have you pulled the valve cover off to look?
As long as a pushrod didn't get wedged in away from its seat, I wouldn't think you would have caused a piston/valve collision.
Anyway, I'd at least pull the valve cover and see what you've got.
Old Mar 23, 2010 | 10:02 PM
Old Smoky's Avatar
I'm guessing that the popping sound is compression going back out the intake. I would think that there is an extra 10-20thou between the valves and piston. Severe engine damage is possible, but as long as you didn't really botch it, I bet that you can put them into spec and be fine (inspecting everything of course). Fingers crossed......
Old Mar 24, 2010 | 07:32 PM
Lost Lake's Avatar
WOW!! That could be REALLY BAD!
Good luck man....
Old Mar 24, 2010 | 09:36 PM
Spooler's Avatar
Not good as stated.
Old Mar 26, 2010 | 09:50 AM
Diesel87's Avatar
I got lucky all the valves are in place. Only problem is a bent pushrod. Thanks for the help. I don't know what I was thinking!
Old Mar 26, 2010 | 10:15 AM
Jeff in TD's Avatar
Good deal.
Old Mar 26, 2010 | 10:23 AM
rip 112's Avatar
Whew that was close man...
Old Mar 26, 2010 | 11:54 AM
White Ghost's Avatar
heck that was scarry! you are so lucky. when i read your post i thought your truck was toast. good luck
Old Mar 28, 2010 | 08:50 AM
big-c's Avatar
wow guy you were extremly lucky -when doing internals on an engine make a check list and follow it
Z-MAN
Aug 18, 2013 10:51 AM
cbrahs
Nov 1, 2011 11:00 AM
jdwest
Feb 15, 2008 03:54 PM
joelsepf
Jan 17, 2007 07:35 PM
acook
Dec 20, 2006 09:08 PM
