Update on my Toyo tires questions
Hi just wanted to tell everyone thanks so much for all the help with all my tire questions. well i got my Toyo open country At tires put on tonight. My truck is back to driving like a truck again. Man i can not beleave the diffrence the way my truck drives compared to the way it used to with the coopers. Ok what psi is everybody running in there Toyo tires?? Thanks again guys. Now if i could just get it to run like a CTD truck should. lol
Thanks Mopar72
Thanks Mopar72
I don't know what size you ended up with (fix your sig) but in my 285/75s I run 55 front and 45 rear unloaded on the highway and around town. 55 or 60 all around with a load. 45 front and 35 rear in the snow.
John
John
Sorry about that guys. I updated my sig. but i bought the Toyo open country A/T in a 285/70/17. right now i have 80 psi in them. the place i bought the tires from only put 42 psi in them. So do you think 80 psi is to much? Thanks Mopar72
80 PSI sounds right if you want to carry the maximum the tire is rated for, or you want to jar your teeth out. Otherwise you might lower it a bit.
John
John
Most guys put 10 psi more in the front than the back due to the extra 1100 lbs of engine up there. I need to check but I think I'm 55 up front 45 out back. I try to put just enough air in them so they wear evenly all the way across the tread. When they're new you can watch the little "strings" that stick up from the molding process wear off in the first hundred miles or so. They'll wear off in the middle first if you have too much air or on the edges first if not enough. More air = less rolling resistance and better economy but I like mine to wear evenly..
May 29, 2009 10:24 PM
Mopar72
31
Apr 28, 2008 11:39 AM
sakisaki400
23
Dec 31, 2006 10:17 PM
