Turbo question
Old Feb 4, 2006 | 03:05 PM
Rambunctious1's Avatar
Question Turbo question
I had my intake tube off of the turbo recently. While I was looking at the blades on the turbo, I noticed a film that looked like fine dirt on the blades. It looked kind of like a household fan that hasn't been cleaned in a while. Meaning the leading edge of the blades had a small amount of this film and the pattern got larger toward the outer edge of the blade. I rubbed some off with my finger to see if it was dirt. It didn't feel gritty or anything, but it definitely rubbed off on my finger. I have about 8500 miles on the motor and was thinking that it's still pretty new to be having a "dirty" turbo. So here's the question: Is this normal or should the blades still be perfectly clean? The intake tube didn't seem to have any dust or dirt in it and the filter looks fine (no dirt on the outlet side of it). I'm kinda starting to worry about it. Thanks in advance.
Old Feb 5, 2006 | 06:31 AM
dogger's Avatar
Turbo blades
Do you have an aftermarket air filter? If it is not properly serviced it can pass very fine particles. If you have a stock filter does it fit properly, is the filter seal pliable and set in the box correctly, or is it very dirty? Are all your intake boots properly installed with no defects or tears and are the boot clamps from the air filter to the turbo intake tight? Of course these are obvious points but at least it is a place to start. Good luck.
L8r,..............dogger
Ada381
Feb 10, 2008 07:58 AM
j
Jan 9, 2004 08:19 AM
Haulin_in_Dixie
Jul 21, 2003 11:14 AM
redram
Dec 10, 2002 09:54 AM
