Turbo Cool Down
Old Sep 5, 2007 | 02:26 PM
AkitaSumo's Avatar
280 for me. The temp will go back up right after shut down about 20-30 degrees.
Old Sep 5, 2007 | 04:43 PM
levigarrett76's Avatar
i always let it cool to 300, ive found turning the ac off makes it cool much faster
Old Sep 5, 2007 | 04:50 PM
2rowdy's Avatar
Are you guys that are talking about 325 or less at pre-turbo or post turbo. I sat at dinner for ten minutes at 75 degrees outside temp. i just drove probably for 5 miles tops and at pre-turbo it never went below 400. I did shut the a/c off to get it to that.
Old Sep 5, 2007 | 05:04 PM
staarma's Avatar
I have my timer set for 350 right now. Works for me.
Old Sep 5, 2007 | 05:43 PM
dieselengineer's Avatar
I have pre and post EGT. The post is lower then the pre. I believe the post EGT is the correct one to use for the cool down temp set point. It is just on the discharge side of the turbo outlet. The pre EGT is in the manifold and the iron stays hot after a heavy pull. Without a load, the post EGT cools down quickly (less then a minute to less then 300*) After a hard pull, it takes much longer to cooldown. I was hoping that the new Quad modules would have cooldown option.
Old Sep 5, 2007 | 05:45 PM
txfiremedic's Avatar
Mine is pre-turbo, in the manifold and it cools down to 320 fairly quickly.
Old Sep 5, 2007 | 06:03 PM
mjsandt's Avatar
yeah I was also hoping for the Quad Commander to have a cooldown option soon, but I couldnt pass up the deal I found on one, so I got it. Maybe mine will be able to be updated if they every add that as an option.
Old Sep 5, 2007 | 08:26 PM
03qclb5spd's Avatar
How?........
Old Sep 5, 2007 | 10:11 PM
TonyB's Avatar
I've seen as much as a 50F increase after shutdown - latent heat in the manifold / turbo / head.
Tony
Old Sep 5, 2007 | 10:26 PM
SundayMoney's Avatar
Originally Posted by 03qclb5spd
How?........
Heat soak
The same thing happens with fluids in your truck. After shutdown,the fluids stop moving and soak up some of the heat from the engine.
Old Sep 5, 2007 | 11:19 PM
03qclb5spd's Avatar
I've turned my truck off and turned the key back on which allows the guages to read and have never seen an increase of more than 8-10 degrees, most of the time there is little to no increase at all on mine.
Varmint
Mar 26, 2004 10:40 PM
hvanflee
Oct 19, 2003 10:53 PM
Drafter
May 26, 2003 07:30 AM
hellotbone
May 2, 2003 10:03 AM
