Turbo boost jumping
Old Dec 14, 2012 | 11:47 AM
DESERTDODGE's Avatar
Turbo boost jumping
My boost gauge is jumping around very quickly. I'm pulling a 14k trailer, psi went to 40. I try to keep it down by letting off the fuel. Now it will jump around and on a hill went to 0 psi until I downshift and then went to 27 to32. Got it back home and am trying to get it going.
ANY HELP WOULD BE GREAT!!
Old Dec 14, 2012 | 02:17 PM
BigIron70's Avatar
Cummins Guru
Mechanical gauge or electronic? do you have lag in power when boost goes to zero? Are you using stock sensor? Any codes setting or check engine light? Hear any noise like loud hissing sound when boost goes to zero?
Old Dec 14, 2012 | 02:22 PM
man gauge in intake manifold. lost all power when it went to 0. no light or codes. No noise like it has a leak. Suspect waste gate controller wiring or sticking. I don't know how to test it without a scanner.
Old Dec 14, 2012 | 06:32 PM
michael/edge's Avatar
Were you running the superchip while towing? i have seen the superchip do some crazy surges before .
Old Dec 14, 2012 | 06:35 PM
Spooler's Avatar
Do you have the 05' with the plastic end tank CAC?
Old Dec 16, 2012 | 10:35 AM
Thanks to all of you that use this this forum. I found the problem, the wires going into the turbo controller had worn off the insulation and where shorting out to each other. Some shrink wrap and tape, road test and it's ready to go. THANKS AGAIN.
doomgaze
Oct 23, 2003 04:59 PM
joking
15
Sep 19, 2003 06:02 AM
DODGEBRIAN
Apr 5, 2003 12:34 AM
pull superbee
Jan 30, 2003 09:26 PM
