turbo bark, and wheel issues...long day already.
Old Mar 26, 2008 | 12:04 AM
Rollin'_Coal's Avatar
Sorry for the long post in advance. For you guys that are wondering, turbo "bark" or turbo "surge", happens when you are heavy into the throttle building boost and then step off in a hurry, the engine unloads and slows down, no longer taking in all of the air the turbo is forcing into it. This causes the excess pressure in the intake between the turbo and the engine (the whole volume of the intercooler) to depressurize and since the engine isn't using the air, it escapes past the blades of the turbine. This can cause damage but its not nearly as bad on a stock turbo as it is on an aftermarket higher volume higher pressure turbo. Turbo surge will damage the turbo internals if you keep doing it but its not something that happnes after three times and it explodes. So if you are still running your stock turbo it isn't really that big of a deal unless you do it alot. As for the question of the whooshing sound during acceleration, that is the wastegate dumping excess boost. If I remeber correctly, it will try to maintain about 22 psi on the stock turbo. I have a boost fooler on my truck and it will spin to 45 psi and sit there till I let off.
Old Mar 26, 2008 | 12:59 AM
bekim's Avatar
Originally Posted by ian515
does it sound like short bursts of "woosh" "woosh"? and like its comin from the turbo side of the engine?
Yeah a whooshing that is very pronounced, kinda scares ya the first time or two.
I get it if I mash the throttle and let off too quickly. If the programmer is set a couple of notches higher it will happen everytime if you don't ease off the throttle gently.
Mike
Old Mar 26, 2008 | 04:06 PM
radshooter's Avatar
Thanks for the "Turbo 101" class Rollin' Coal. That helps explain a lot of things.
TDIwyse
15
Dec 6, 2008 11:19 AM
Chass
Sep 7, 2006 07:27 PM
OldRam
Feb 16, 2006 06:41 AM
gatf4
18
May 31, 2005 04:31 PM
Bobcat698
22
May 17, 2005 09:58 AM
