turbo bark, and wheel issues...long day already.
quick question about wheels. when I turn hard left or right, it feels like the front wheels are "biting" almost, kinda like it is in 4hi. and if I listen, I can almost hear it popping/cracking/snapping. balljoints? also, I dont know what part this is, it is an arm that comes off the steering linkage, and goes to the right front wheel, when I grab it, I can actually wiggle it up and down. am I wrong to think that that shouldnt happen being that it is attached to my steering? as far as steering goes, everything seems normal, aside from the biting issue. it does pull a little to the right.
now, on to the turbo bark. I am assuming that's what it is. I went to merge, and some idiot wasnt moving over into a perfectly good, empty lane. I went to accelerate, than figured I could just be patient and slide in behind him. I let off the gas and heard a rushing of air in two short bursts. turbo bark right? that is the second time I have heard it since i bought the truck. first time I was starting the truck and accidently let off the key before it started, and heard it bark. should I be worried, or is this ok everynow and then?
thanks guys.
thanks guys.
might be a front U-joint in your wheel... mine sounded like that when it went away. Jack it up, rotate your wheel forward/backward while watching the u-joint. If it's bad you'll see the slop in it.
Yep, that's turbo bark. Mine does that when I shift fast while building boost... try not to do it too often!!!
I have a problem with turbo bark (hope that is what it is) when I pull our big fiver in the mountains. I will start up a hill in 5th and have do downshift, sometimes all the way to 3rd before I get over the hill (mountain). If I am not real careful how I let off the skinny pedal before I push the clutch to the floor, it barks real bad. Of course, my boost is up around 22lbs when this happens. If I ease off the throttle just a little before clutching, and let the boost drop a little, it does not happen. You know what they say.....timing is everything.
Does this sound like turbo bark to you guys, or do I have something else to worry about?
Thanks.
Thanks.
Thanks.
Thanks.
if I remember how it was explained to me, it was backpressure forcing the blades on the turbo to rotate the other way...I could be mistaken though. thats why it is not recommended to let happen a lot since its really bad on the internals I guess.
Sounds like it would be really hard on the bearings.
Is it the sudden release of pressure when I push in on the clutch? Where does the back pressure come from? Seems like the turbo would be pushing air at a million RPMs, why would it not keep pushing air just because I pushed the clutch? Or is it because when the clutch is pushed, pressure released, does the turbo speed up because of less pressure? Are we hearing the turbo speed up? This is driving me nuts trying to reason this out.
Don't think this is turbo bark, but if I get on mine while I'm already moving (lets say, 35 mph to 55 mph) I get a "whoosh whoosh" sound right when I burry the throttle but then goes away but while rpms are climbing, is that just excess boost, because my foot is still in it?
I don't have gauges (yet) and the 5.9 is completely stock with an auto behind it.
