turbo
Old Dec 29, 2005 | 07:38 PM
StrokeThis2500's Avatar
turbo
turbo silencer ring what is it if its removed what benefit do i get
Old Dec 29, 2005 | 09:02 PM
runamuk's Avatar
Noise, wonderful noise! That is all!
Rick
Old Dec 29, 2005 | 10:26 PM
jd2015's Avatar
Where is the silencer ring located, I would like to remove mine for a bit more turbo whistle.
Old Dec 29, 2005 | 10:38 PM
dodgezilla04's Avatar
remove the black corrugated hose from the airbox to turbo inlet, dont forget about your air temp sensor on the hose. The ring is the stamped steel disc inside the compressor inlet, GENTLY pry the snap ring out of the inlet with a small screwdriver and then the silencer ring should fall out, if not use your finger inside the center hole to help it. Put the hose back on, dont forget about your air temp sensor on the hose. Should take all of about 5 minutes.
Old Dec 30, 2005 | 11:45 AM
could you post some pics i would hate to mess up even thought it sounds fairly simple
Old Dec 30, 2005 | 11:49 AM
ratat98's Avatar
go here: scroll down and it explains it pretty good
http://www.dodgeram.org/tech/dsl/FAQ/turbo_faq.htm
Ada381
Feb 10, 2008 07:58 AM
j
Jan 9, 2004 08:19 AM
Haulin_in_Dixie
Jul 21, 2003 11:14 AM
redram
Dec 10, 2002 09:54 AM
