Turbo
Old Oct 28, 2006 | 05:41 PM
3rdGen's Avatar
Turbo Bolts!!
I was looking under the hood today and looked at the turbo in particular. I noticed that the pass side bolts (bolts the manifold to the turbo) had nuts on them. I looked at the front drivers side (closest to engine) bolts and it didnt have a nut on it. I couldnt get close enough to see if it was sheared but it wasnt protruding through the manifold flange(??). Is there supposed to be a nut on these bolts? Gonna take come pictures and check the rear DS bolt. Pics are in my profile awaiting approval.
Old Oct 28, 2006 | 08:21 PM
3rdGen's Avatar
Noone knows anything about this? I had it at the dealer a month or so ago for something, cant remember, but they tightened all the clamps and stuff for the intake, prolly the turbo as well. I thought they mioght have over tightened it or something. Oh now I remember, I had excessive smoke on a stock truck, they thought it was an intake leak or something, its fixed now, kinda. Thanks for help ahead of time.
Old Oct 28, 2006 | 08:46 PM
Geico266's Avatar
I'm sure they are fine dude. I'm sure some are threaded in the flange & some are pass through and bolted. If they were loose you wpoulf not be making boost.
Old Oct 28, 2006 | 08:53 PM
3rdGen's Avatar
Okies. Thanks for the reply. Just looked wrong to me for some reason.
Old Oct 28, 2006 | 10:30 PM
dodgezilla04's Avatar
the stud is broken dude. just swapped my turbo in august and I had 4 studs, 4 nuts. unless the 05's are different that the 04.5's.
Old Oct 29, 2006 | 06:12 AM
MikeyB's Avatar
Mine is mounted the same way.
MikeyB
Old Oct 29, 2006 | 06:22 AM
PourinDiesel's Avatar
The studs and nuts oppose each other.
One set of studs is threaded into the manifold the other set is threaded into the turbine housing.
So you will only see one set of nuts pointed up the other set is pointed down.
Old Oct 29, 2006 | 11:42 AM
3rdGen's Avatar
Thanks for the info Pourin Diesel. Opposing studs it is. Thanks for all the info folks. Yall RAWK!
Ada381
Feb 10, 2008 07:58 AM
j
Jan 9, 2004 08:19 AM
Haulin_in_Dixie
Jul 21, 2003 11:14 AM
redram
Dec 10, 2002 09:54 AM
