Truck Running Like Water In Fuel
Old Nov 14, 2006 | 08:28 AM
appydriver's Avatar
Hey, My truck is acting like a gas burner that has a little water in the gas. It comes and goes. I changed the fuel filter 1500 miles ago. Any Ideas?
Old Nov 14, 2006 | 08:40 AM
TonyB's Avatar
You may have had a bad tank of fuel. i.e. contaminated with quite a bit of water.
Try draining the fuel/water separator for the next several tanks, or even better, once per day. To see if you really have water in fuel, drain the separator into a container to see if there is water present.
HTH
Tony
Old Nov 14, 2006 | 02:44 PM
DBLR's Avatar
If you think you have water in your fuel then add 16-24oz of Power Service in the white bottel to your fuel ASAP. Also are you useing Fleetguard or Mopar fuel filters as some other brands will not work well with the water seperators in your truck and allow water to get through and in to your injectors? FYI water can and will screw up and injectors!
Old Nov 14, 2006 | 03:39 PM
appydriver's Avatar
I don't really think it has water in it, but I dont' know, the water in fuel light has never come on and I get my fuel from the same place 90% of the time. I have some seafoam injector cleaner I may run in it also I'll try draining the water seperator.I'm using wix filters and have never had any problem with them on any of my tractors or combine.
Old Nov 14, 2006 | 04:19 PM
bluepp's Avatar
Have you fixed the open elbows on top of your fuel tank that can let water and crud right into your tank???? There was a recall for the o6s but this has been a problem for several years. Dirty fuel is what takes out these lift pumps.
Old Nov 14, 2006 | 11:36 PM
Gary C's Avatar
After one bad experiance I now go out of my way to ONLY fill at truck stops for fresh fuel...
1985cucv
Feb 27, 2010 06:56 PM
BLACKDODOGE
Jan 2, 2008 10:29 PM
Hayseed
Feb 13, 2007 11:00 AM
lovinCTD59
Oct 7, 2006 08:02 PM
Dusty Ratcliff
May 3, 2006 08:55 AM
