Truck has no power
Old Nov 4, 2009 | 06:15 PM
chighley_00's Avatar
Truck has no power
I bought a smarty a few weeks ago I installed it and it didn't act like it had any power. So I have installed many different tunes. Well nothing gives the truck much more power. So yesterday I took everything out of the truck and ran it stock today. Well the truck has no power at all. I unhook every thing on the edge except the data cable so I can use the gauges. My fuel pressure is at 20 PSI at the CP3. I change my fuel filter just to be safe boost pressure on my mechanical gauge is about 25. I did a speed test and from 0-60 is 15.1 seconds. Any thought on what to try?
Old Nov 4, 2009 | 07:12 PM
psd1's Avatar
Sorry, no advice. My truck does the same thing once in a while using the Triple Dog...like I step on the pedal and nothing.
Old Nov 5, 2009 | 07:39 PM
CRToney's Avatar
wastegate problem maybe. Pinch it off (hose) with needle nose visegrips and see what happens. Is the truck a stick or auto? You should see 25-26 psi under full load if you have a 305-555 truck. Over that with wastegate closed and smarty.
Crallscars
16
Jul 25, 2012 04:59 PM
GUMP
May 26, 2008 08:26 PM
jtalaiver
20
Jun 22, 2007 10:36 AM
FDX
Jan 15, 2007 01:47 PM
jaredsund
Nov 1, 2006 02:44 AM
