Truck getting a little warm
Old Aug 2, 2009 | 09:26 PM
Flanman5's Avatar
I pulled the trailer this weekend down to Sask Landing to the lake and it waas running warmer then normal, the tranny was running warmer then normal as well.
The Rads are fairly clean, what else coulld it be?200000km on the old girl
Old Aug 3, 2009 | 02:31 PM
N'Stuff's Avatar
my buddy had this problem this past weekend.
noticed his radiator overflow hose had come disconnected from the over flow bottle. over time he had lost enough fluid for it start running hot. may wanna check fluid level.
Old Aug 3, 2009 | 02:43 PM
rip 112's Avatar
Check your water pump weep hole, see if its leaking. Also how longs it been since you changed your coolant???
Old Aug 4, 2009 | 08:30 PM
Flanman5's Avatar
The rad is fairly clean itself. The hose is connected and working
The fluid has not been changed since i owned the truck (2Years)
The weep hole is dry and not weeping
Rad is topped up
Any other ideas?
Old Aug 4, 2009 | 09:58 PM
rip 112's Avatar
Well possibly temp changes in ambient air. It is the middle of summer. How hot are you temps getting? I can see about 210* on the gauge, right past the mid mark when towing. When unloaded it stays at 200 til I get on it hard, then it will switch to 210 and back down.
Old Aug 4, 2009 | 11:16 PM
Flanman5's Avatar
220 and the tranny was running between 180 and 200
mtb1982
55
Jan 20, 2020 10:45 AM
klx650a2
Jul 22, 2008 06:47 PM
herb
Jul 18, 2008 08:25 AM
Jambbii
Aug 10, 2004 06:12 AM
