Truck feels like it's got no guts!
Old Nov 20, 2007 | 11:34 PM
Crabjoe's Avatar
I've got 92K miles on my truck and for the last 10K miles, I feel like the truck is losing power. The truck starts and idles fine. I does put out a white poof of smoke at times, but as of yesterday, it's putting out dark smoke after a restart.
What I mean by restart is this. Lets say I drive to work and let it sit for a few hours then get back in.... When I get moving again and I give it more then the normal take off throttle, I get a good dark cloud of smoke. After that on dark cloud, I don't get any smoke no matter how hard I get on it.
What could be causing this problem??? Could my lift pump or maybe an injector be going bad? Is there anything I can check here at home?
Thanks!
Old Nov 21, 2007 | 08:05 AM
Farmer Davis's Avatar
Might want to check the fuel filter if you hadnt already,then the lift pump. Sounds like the fuel pressure is fluctuating some (bad lift pump). I would rule these out before looking at injectors.
Old Nov 21, 2007 | 09:08 AM
Timmer's Avatar
boost leak?
Old Nov 21, 2007 | 07:07 PM
Crabjoe's Avatar
I tried a new fuel filter and it didn't make any difference. I guess I'll need to get it into the shop for them to test the pump.
BTW, is there a way to check boost here at home?
Old Nov 21, 2007 | 09:04 PM
RRAMctd's Avatar
Well if you have a boost leak you would probably hear it blowing air when you boot on it. I blew my intercooler and it sounded like I cut the end off my air hose. The other way is to get a boost guage.
Rick 12v CTD
Aug 9, 2009 11:34 AM
Fishhead
Jul 17, 2008 10:27 AM
bigair
Apr 26, 2005 08:26 AM
70DUSTER
May 15, 2003 02:53 PM
gunracer1
May 8, 2003 05:59 AM
