trouble codes ??'s
Old Oct 14, 2007 | 06:56 PM
coontz0473's Avatar
trouble codes ??'s
Guys a friend of mine has an 04 305 motor with NV5600 and has a couple of codes we need some help with.
The codes are: P0236 (I think is TC Boost System) If that is it, what causes it and how do you fix??
Second one is: P0251 ( I think is Injection Pump Fuel Metering Control "A" Malfunction) If this is it, what causes this and how do you fix??
He has a Quad Race Box and AFE stage 2....Other than that he is stock.
Been running the Quad and Stage 2 for the last 20k...First codes he's had, anybody got any suggestions?????
Thanks..
Old Oct 14, 2007 | 11:25 PM
53 willys's Avatar
SYMPTOM
P0251-CP3 PUMP REGULATOR CONTROL
WHEN MONITORED
When the ignition is on.
SET CONDITION
The ECM detects a discrepancy between the PWM supplied to the Electronic Fuel Control Actuator and the PWM returned from the Electronic Fuel Control Actuator.
POSSIBLE CAUSES
  • Intermittent condition
  • Fuel control actuator (FCA)
  • (K31) return circuit open from FCA to ECM
  • (K65) 5-volt supply circuit open from FCA to ECM
  • (K65) 5-volt supply circuit shorted to voltage
  • ECM
SYMPTOM
P0236-MAP SENSOR TOO HIGH TOO LONG
WHEN MONITORED
Ignition on.
SET CONDITION
The intake air pressure is above a calibrated value past a calibrated amount of time.
POSSIBLE CAUSES
  • Other codes
  • MAP sensor
My guess is a bad FCA and the bad FCA is causing the P0236 code......
Old Oct 15, 2007 | 03:08 PM
coontz0473's Avatar
Thanks ******....
Where did you find this info? I thought I found the right thing, but mine sure doesn't match yours?
Is a Fuel Control Acuator(FCA) expensive or easy to replace??? Not sure what this is or what it does in caveman terms
Thanks again for your help...Greg
Old Oct 16, 2007 | 03:56 PM
coontz0473's Avatar
Can anyone tell me what a FCA actually is in caveman terms? Are they expensive or difficult to change, my buddy sweatin bullets here?
Thanks for the help so far....
Old Oct 16, 2007 | 05:28 PM
bob4x4's Avatar
The FCA controls how much fuel enters the high pressure pumping chambers.It is easy to change,not too much money.
Bob
Old Oct 16, 2007 | 09:26 PM
53 willys's Avatar
it's the small black actuator on the back of the CP3....tell him to buy a factory service manual...it will tell him most of the stuff he wants to know
Old Oct 17, 2007 | 08:54 AM
coontz0473's Avatar
Thanks guys...we'll start looking for it today
ridlangus123
Dec 30, 2013 08:36 PM
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
gofastman
Jan 6, 2003 04:17 PM
