Parking Brake
you can tighten the cable under driver's side or adjust the pads. they are drum brakes internal to your rear rotors. you should use a brake adjusting tool as getting to the star adjuster is a pain without removing the tire and rotor. If you have adjusted drum brakes before same thing. You may want to check to see if the pads are still good though first.
duke1n
15
Jan 19, 2005 02:22 PM
RamDan03
Nov 9, 2003 10:26 AM
