Transmission Vibration
Old Oct 1, 2013 | 06:27 PM
flbrit80's Avatar
I have noticed a slight vibration when pulling away from a complete stop. This when pulling my 6,000lb trailer and using Tow/Haul mode. It's not noticeable without the trailer.
Without the trailer, the truck does not pull away smoothly. It lurches slightly, and you hear/feel the thud from the rear axle. You have to be really light on the throttle to avoid this.
Are these signs of a torque converter or transmission problem?
Old Oct 1, 2013 | 09:16 PM
MeanDoggy's Avatar
Check your driveline for possible bad u-joints or carrier bearing.
Old Oct 2, 2013 | 12:58 AM
Fiftygrit's Avatar
Have you ever serviced the trany, fluid change and adjusted the bands, I do mine every 30k miles. 137k and still shifts fine.
Old Oct 2, 2013 | 06:58 AM
flbrit80's Avatar
Yes. Trans. oil has been replaced a few times. Had a problem early on with constant shifting 1-2-1 at low speed, fixed under warranty. I don't believe the bands have been adjusted. But the truck only has 68k
Dauntless
15
Aug 30, 2016 08:37 PM
Valv
Jul 19, 2009 10:32 AM
drclock
Dec 17, 2007 10:37 PM
dodgedsl03
Jan 18, 2007 10:08 PM
Davidp
Mar 19, 2003 11:29 PM
