Transmission temp
Old Sep 9, 2011 | 08:28 PM
colliwood's Avatar
Transmission temp
What's the regular operating tempature for the transmission ? Is it about the same as engine coolant tempature . I ask because it's been +30 for a while and I have been running temps about 205 . Is that to High?
Old Sep 9, 2011 | 09:43 PM
larrybartlett's Avatar
not pulling I run about 185, if you have some miles on your truck you might clean your cooler, could be full of dirt and bugs
Old Sep 10, 2011 | 09:17 AM
no_6_oh_no's Avatar
Operating temp is 140-240 degrrees. The observed temp will depend on what is being used to read it, where the probe is located, ambient temp, and the current usage of the truck.
On a hot day in stop and go traffic that temp is perfectly normal. On a hot day driving at road speed and reading the temp thru the data port, normal.
On a cool day driving empty at road speed, not normal. If it used to run 190 under the same conditions, not normal.
Need mor einfo on how, what, when, where of that temp reading and your truck info.
Old Sep 11, 2011 | 09:37 AM
colliwood's Avatar
I am getting my readings from my edge attiude with juice cts. I believe the probe is located just above the trany pan
Old Sep 11, 2011 | 11:51 AM
no_6_oh_no's Avatar
If the probe is not in the pan or the hot line then the readings are not accurate.
ngkefalides
0
Aug 12, 2008 08:33 PM
Racing_Joe66
Jun 12, 2007 05:06 AM
jaconst
Jun 25, 2006 10:23 AM
turbox2
Feb 6, 2006 07:44 PM
firesine
Nov 24, 2005 10:58 AM
